Results 1 to 7 of 7
Thread: Pcv system
  1. #1
    Member baggertim's Avatar
    Join Date
    Feb 2019
    City
    millington
    State
    Michigan
    Posts
    56
    Pcv system
    2009 streetglide seeing oil around pushrods ,was going to look into pcv breathers,question is there actually filters somewhere in the air cleaner system to clean or replace,and are they readily available?
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    538
    There are breather assemblies under the rocker covers. They each contain a one-way umbrella valve and an oil vapor coalescing filter. They may need replacing on an 11 year old bike. The umbrella valves are rubber and eventually deform from heat and oil exposure.
    They vent out through the hollow breather bolts that attach the air cleaner to the heads.
    2019 FLHCS
  3. #3
    Join Date
    Feb 2019
    City
    millington
    State
    Michigan
    Posts
    56
    Many thanks,i would assume stocked at the dealer.
  4. #4
    Senior Member yegg's Avatar
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    126
    I just replaced mine not too long ago. Here are the pics I have. I am sorry but I thought I had a shot of each piece. You buy it as a "kit" at the dealer. It is surprisingly reasonably priced. I forget where I read it but I could have sworn that I saw that these two assemblies (one per rocker box) should be replaced every 25 or 30 thousand miles. I can tell you that when I pulled mine out, the filters just crumbled to dust. After I put the new ones in I noticed a reduction in oil blow back as seen in my Roland Sands Clarity air cleaner cover.
    Top to bottom: Rocker Box Base - Rocker Arm Plate w/ Rocker Arms Installed / Breather Assembly
    Better Shot Of: Rocker Arm Plate w/ Rocker Arms Installed / Breather Assembly
    Where the entire assembly sits in the rocker box
    Side by side comparison so you can see one installed and one not installed
    Rocker Arm Plate installed and ready to mount the breather assembly
    I have a few more pics if you need them but apparently I can only post 5 at a time.
    Ride safe.
    Ride Safe,
    Elliott
    2015 FLHXS - Amber Whiskey
  5. #5
    Join Date
    Feb 2019
    City
    millington
    State
    Michigan
    Posts
    56
    awesome,thanks ,where did you find your torque specs?
  6. #6
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    126
    Torque specs are in the service manual. If you need me to post them, let me know. Also, if you replace the breather assemblies yourself, make sure to do what I didnít. Before you tighten bolts down, make sure there is no oil in the bolt holes. I blew out the bottom of one of the blind holes which put a hole in my cylinder head. I was able to fix it with some high temp gasket maker but Iíd avoid that if possible!
    Ride Safe,
    Elliott
  7. #7
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    126
    Ride Safe,
    Elliott
Posting Permissions
  • You may not post replies
  • You may not edit your posts
