Results 1 to 9 of 9
  1. #1
    Prospect
    Join Date
    Aug 2020
    City
    Las Vegas
    State
    Nevada
    Posts
    13" Legend Revo vs Revo-A
    I have a 2009 StreetGlide with OEM shocks. I plan to switch to 13" Revo rear shocks. Money is an issue but I could stretch to get the Revo A's. I know that offers adjustable damping but is it worth the extra money? The Revos are set to #3 damping, which I understand is the most commonly-selected option.
    If I really need to spend the extra money I will but I am a fairly conservative rider, weigh only about 190#, pack lightly when touring and ONLY ride 1-up, never 2-up.
    Do I need to go with the Revo-A's, or will I be just as happy with the Revo's?
    Thanks!
  2. #2
    Senior Member Fatbob Frank's Avatar
    Join Date
    May 2017
    City
    Monona
    State
    Iowa
    Posts
    162
    I went with the standard Revos on my 2017 Streetglide and have no regrets.
    The rural Iowa roads around here are brutal, but I haven't felt like I should have spent the extra for the Revo-As.
    I drive way too fast to worry about cholesterol...
    2017 FLHX
    Cobra 909s
    Screamin Eagle intake.
    S&S 465 cam
    Legend suspension
    Superior Blue
  3. #3
    Founding Member
    Join Date
    Sep 2012
    City
    Statesville
    State
    North Carolina
    Posts
    528
    Quote Originally Posted by MarkinVegas View Post
    Thanks!
    In my opinion, unless you plan on changing the weight around on the bike quite often; which is sounds like you will not be; the REVOs should suit your needs just fine. If you switched between 1-up / 2-up or changing the amount of luggage carried in your bags often it would probably benefit you to have the REVO-As.
    Hope this helps!
    Lindsey :0)
    Lindsey Trausch
    www.IronAcesSpeedShop.com
    '10 Street Glide
    - Iron Aces Street Glide Mount
    - RC Components Nitro Wheels - 21x3.5" / 18x5.5"
    - Klock Werks FLARE Windshield
    - Klock Werks Curvaceous Dash
    - Jac-Knife Highway Pegs
    - Battistini Wireframe Brake / Shifter Levers
    - Arlen Ness Modular Bagger Apes
    - Arlen Ness RAD III Hand Controls
    - Corbin Gunfighter Seat
  4. #4
    Prospect Claude's Avatar
    Join Date
    Aug 2020
    City
    Montreal
    State
    N/A
    Posts
    Hi Lindsey
    I need brackets for my Revo Arc reservoirs. Since I own a 2010, Legend doesn’t make them. Do you know someone who makes some or can make some from scratch?
    Claude
  5. #5
    Founding Member
    Join Date
    Sep 2012
    City
    Statesville
    State
    North Carolina
    Posts
    528
    Quote Originally Posted by Claude View Post
    Hi Lindsey
    Claude
    Thanks for the message Claude. Unfortunately I do not know of any other bracket manufacturers for these brackets other than Legend and as you eluded to, they are only compatible on '14 & newer Touring models.
    Sorry I couldn't be more helpful!
    LT
    Lindsey Trausch
    '10 Street Glide
  6. #6
    Prospect 1BdBagr's Avatar
    Join Date
    Jun 2016
    City
    Upland
    State
    California
    Posts
    4
    Lindsey i'm kinda in the same boat as the OP....except i somedays ride two up, somedays pack the tour pack up and somedays i ride it hard in the canyons. I rode a 2020 Road King special at Legend Suspension in SD during Sturgis with the front cartridges and the 13" Revo A's w remote reservoir. It rode as i expected so much better than stock. Other than the extra adjustability with the remote reservoir, i kinda doubt i'll ever ride it hard enough to be utilizing the remote reservoir's capacity. On the other hand i'd rather cry once and get the best one. lol. I'm not going to do the cool guy mounting of the reservoir up high so anyone can see it, i'm going to mount it low where's more subtle. I think it's $500 difference between the two .Thoughts?
    Tim
    2015 Street Glide Special Blacked out, 2018 CVO 21" front wheel, Drago 2-2 head pipe w CFR's, PM air cleaner, LED's headlight/signals, stock paint and engine/trans (103 w PC-V + six speed)
  7. #7
    Founding Member
    Join Date
    Sep 2012
    City
    Statesville
    State
    North Carolina
    Posts
    528
    Quote Originally Posted by 1BdBagr View Post
    Tim
    Thanks for the post. In my opinion, I feel like with the different types of riding you do then you need to at the very least consider the Legend REVO-A's since this will provide 6-positions of rebound adjustments for fine-tuning between different riding styles you are doing.
    If budget is not an issue and you are wanting the 'top shelf' in coil-overs then I'd consider the REVO-ARC Remote Reservoir Shocks which will give 7-positions of rebound adjustments PLUS 7-adjustments for compression. Both of these combined provide even more fine-tuning capabilities especially for those days when you are riding hard in the canyons, for example. The only downside that I have seen in some forum posts going this route is that if you don't really know what each adjustment does and how they work together for a plush ride, you kind of run a slight risk of creating a worse ride than before. This can certainly be straightened out if you talk to the techs at Legends, but some in most cases these folks get frustrated with their purchase and eventually give up.
    All that said, I feel like both the REVO-A or the REVO-ARC would be a good choice for you personally based on your feedback however, it will ultimately come down to 1) budget 2) how advanced of a shock you want to get into.
    Hope this helps!
    Lindsey :0)
    Lindsey Trausch
    '10 Street Glide
  8. #8
    Prospect
    Join Date
    Oct 2020
    City
    ITALY
    State
    N/A
    Posts
    What's the weblink fro Revo A's?
  9. #9
    Founding Member
    Join Date
    Sep 2012
    City
    Statesville
    State
    North Carolina
    Posts
    528
    Quote Originally Posted by djkuma View Post
    https://www.ironacesspeedshop.com/pr...rley-davidson/
    Lindsey Trausch
    '10 Street Glide
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
