Results 1 to 4 of 4
Thread: Cylinder Gasket
  1. #1
    Senior Member yegg's Avatar
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    158
    Cylinder Gasket
    Ok, I’m confused. I am doing a top end overhaul and am getting ready to start reassembly. I bought the top end gasket kit and I understand everything I’m looking at with one exception. The gasket kit came with four (4) cylinder gaskets. Why?
    Thanks.
    Ride Safe,
    Elliott
    2015 FLHXS - Amber Whiskey
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    567
    I believe two are for 107 and two for 114.
    2019 FLHCS
  3. #3
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    158
    So I just use 1 on each cylinder since I have the 103?
    Ride Safe,
    Elliott
  4. #4
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    567
    Sorry, Twin cam gaskets are different. Are you sure you don't have 2 head gaskets and two base gaskets? Not sure why you should have two pairs of gaskets.
    In any case, you should use a multi-layered steel head gasket like these or aftermarket. https://www.harley-davidson.com/us/e...Kit/p/16101-01
    2019 FLHCS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
