Results 1 to 2 of 2
  1. #1
    Prospect
    Join Date
    Jan 2020
    City
    Fontana
    State
    California
    Posts
    18
    2014 FLHXS cam upgrade
    I have a 2014 Street Glide Special with less then 8000 miles on it.
    Bought it Jan. last year with only 2200 miles on it SO its still new!
    I am putting a new set of "bolt in" cams in it.
    the Question is "Should" I replace the bearings?
    I am not inclined to seeing it has so little miles on it BUT I am new to the Harley world so I thought I would ask
    Also, I only see one set of bearings for the cams I guess they are the "inner bearings" are there not outer bearings, or are they built onto the Cams?
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    610
    New inner bearings are not essential but recommended practice. You will need to buy a remover & installer tool and don't put them in backwards. The outer bearings are in the cam plate and should be OK. The SE inner bearings from H-D are fine.
    2019 FLHCS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
