Results 1 to 9 of 9
  1. #1
    Men's Hybrid Ultra-Light Old Glory Half Helmet
  2. #2
    Administrator BillyBob's Avatar
    Join Date
    Jan 2012
    City
    Jackson
    State
    Mississippi
    Posts
    1,278
    Quote Originally Posted by Bogus1 View Post
    How do you like it?
  3. #3
    Feels good. I go for my first ride with it on 8/25 on a street glide I am renting. Will let you know after that how it works out for me.
  4. #4
    I like this helmet alot, I bought one this past summer, very light, still wear a full face helmet for colder riding http://www.harley-davidson.com/mcm/m...S&default=true
  5. #5
  6. #6
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Chaska
    State
    Minnesota
    Posts
    1,811
    Should I get the white one or the black one?
    2014 FLHXS: Sand Camo Denim
    H-D Parts Except as Noted: updated 07-Jan-2019
    Front Lighting: Illuminated Hand Control Switches; Auxiliary Lamp Kit; Norman 3000K LED Lamps W/PAR 36 Amber Lens Covers; JW Speaker Evolution II LED Headlight; Amber LED Turn Signals
    Rear Lighting: LED Light Bar; Tri-Bar Fender Brake Light; Tour-Pak and Saddlebag Run/Brake/Turn LED Lamps
    Chrome: Fork Sliders & Covers; Axle Spacer; Fairing Skirt; Curved License Frame; Classic Timer Cover; Docking Point Covers; Windshield Trim; Rear Saddlebag Guards; Radio Trim; Stealth Tour-Pak Rack; Tour-Pak Lamp Trim; Smooth Horn Cover; Saddlebag Hinge Covers; Landmark Fat Round Shift Linkage; Klock Werks Flush Front Axle; Inner Primary Housing; Solenoid Cover; Chopped Engine Guard; Front Engine Mount & Link; Arlen Ness Smooth A/C Cover; Oil Cooler Protection Screen; Kuryakyn Fender Accents and Trim
    Security: Smart Siren II; Brukus TourPack Bullet Secure; Reda Saddlebag Locks; FOBO Tire Pressure Monitors; V-Twin Metal Valve Stems; Micro Start Kit W/Harness & Tire Inflator; Fuel Door Lock; Abus 7000 Disc Lock Alarm
    Engine: 103"; Line2Line Coated Stock Pistons; Andrews 57H cam; S&S Premium Tappets; CNC Ported Heads; SE Wide Band Auto-Tuning Module; SE Pro Super Tuner; SE High Flow Street Cannon Exhaust; SE A&S Clutch Kit; Rekluse Centrifugal Clutch Pack; Dipstick Temp Gauge; S&S Stealth Air Cleaner; Yuasa GYZ Battery, 1.4 kW Starter; Amsoil; Mighty Might Cooling Fans & Accy Switch; GMR Compensaver; Pingel Shifter Shaft; High Output Charging System; SE Spark Plugs & Wires
    Handling: Cartridge Fork Dampening; Amsoil Suspension Oil; 18" Front Wheel; Floating Brake Rotors; EBC HH Brake Pads; Dunlop American Elite Tires; Ohlins HD 773 Shocks
    Comfort: Police Solo Saddle with Coil-Over Suspension; Extended Reach Footboards; SoftBrake 1 Extended Brake Lever & Reduced Reach Clutch Lever; Extended Shift Levers; Fairing Air Deflectors; Freedom 14" Windshield; Klock Werks Ergo Up Bars; Get-A-Grip Hand Grips; Kuryakyn Magnum Plus Mirrors
    Infotainment: Ultra Tank Console with Headset Connection & CVO Insert; Hidden Radio Antenna; GPS Map Update
    Luggage: Four Point Docking Hardware; Solo Tour-Pak Mounting Rack; King Tour-Pak and Lining; Tour-Pak Wall Organizer; Premium King Travel-Pak; Chopped Backrest Pad; Premium Saddlebag Travel-Paks; Innovative Storage Solutions Tool Bags; Saddle Bag Guard Bags & Bottle Holders
    Appearance: CVO Black Gauges; Carbon Fiber Gauge Panel; De-badged Gas Tank; Skull Emblems over Fairing Mirror Holes; Diamond Engineering 12 Point Engine Screws; Allen Hole Plugs; Piston Muffler End Caps
  7. #7
    Join Date
    Jun 2013
    City
    Amesbury
    State
    Massachusetts
    Posts
    85
    Black, of course. Black matches everything. LOL
  8. #8
    Senior Member Scatrgunr's Avatar
    Join Date
    May 2013
    State
    Illinois
    Posts
    109
    They should make a clear one so you can't see it at all.
    2011 FLHX 103"
    Fuel Moto Pro Billet Stage 1 Air Cleaner
    Fuel Moto Jackpot 2-1-2 Stainless Head Pipe
    Fuel Moto Jackpot 4" Slash Up Mufflers
    Woods TW-222 Cams
    Power Commander-V w/autotune
    Yaffe 12" MBB
    Klock Werks Windshield
    Klock Werks Slicer Fender
    HD Floating Rotors
    Progressive Monotubes
    Ohlins HD 159's
    Lindby Twinbar
    And some other stuff...........
  9. #9
    I have the HD Hybrid spoiler. It's very light and fits me perfect.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
