Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Founding Member CWNY's Avatar
    Join Date
    Jul 2014
    City
    Long Island
    State
    New York
    Posts
    293
    Quote Originally Posted by hulkss View Post
    I just put get-a-grips on my bike. So far, with zero miles, I like 'em.
    How about these brass grips: Brass Grips
    Attachment 5388
    Brass grips ? Hope your not serious.
    To each their own...
    Thanks,
    Chris
    2014 FLHXS
    Vivid Black
    V&H FP3 fuel management
    V&H "power duals" with X Pipe
    V&H "high output" slip ons
    Stage 1 "big sucker" air kit
    Harley fork wind deflectors
    GADS tripple tree - wind deflector
    Arlen Ness - deep cut comfort grips
    Saddlebag custom lining-Thanks Tom @ Tijuana Kustoms !!!
    4point w/ det backrest
    Factory seat re-sculpted & shaped for me by Pheonix in Franklin Square NY
    HD Wind splitter 7.5" windshield ( Big thanks to "oneshotoopsmytoe" )
    Instagram name ..... cwny638
  2. #12
    Avons on my bike, only been a couple hundred miles so far but no complaints yet. I do like how they feel and how they look (actually the service guy at the dealership commented about how much he liked all the mods that I'd done, to which I replied that so far all I really did was change the grips )
    2014 FLHXS- Mysterious Red
  3. #13
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Chaska
    State
    Minnesota
    Posts
    1,811
    Quote Originally Posted by CWNY View Post
    What was I thinkin'....there's no points on them to help the bars pass through your body gently with reduced force
    Get these instead.
    2014 FLHXS: Sand Camo Denim
    H-D Parts Except as Noted: updated 07-Jan-2019
    Front Lighting: Illuminated Hand Control Switches; Auxiliary Lamp Kit; Norman 3000K LED Lamps W/PAR 36 Amber Lens Covers; JW Speaker Evolution II LED Headlight; Amber LED Turn Signals
    Rear Lighting: LED Light Bar; Tri-Bar Fender Brake Light; Tour-Pak and Saddlebag Run/Brake/Turn LED Lamps
    Chrome: Fork Sliders & Covers; Axle Spacer; Fairing Skirt; Curved License Frame; Classic Timer Cover; Docking Point Covers; Windshield Trim; Rear Saddlebag Guards; Radio Trim; Stealth Tour-Pak Rack; Tour-Pak Lamp Trim; Smooth Horn Cover; Saddlebag Hinge Covers; Landmark Fat Round Shift Linkage; Klock Werks Flush Front Axle; Inner Primary Housing; Solenoid Cover; Chopped Engine Guard; Front Engine Mount & Link; Arlen Ness Smooth A/C Cover; Oil Cooler Protection Screen; Kuryakyn Fender Accents and Trim
    Security: Smart Siren II; Brukus TourPack Bullet Secure; Reda Saddlebag Locks; FOBO Tire Pressure Monitors; V-Twin Metal Valve Stems; Micro Start Kit W/Harness & Tire Inflator; Fuel Door Lock; Abus 7000 Disc Lock Alarm
    Engine: 103"; Line2Line Coated Stock Pistons; Andrews 57H cam; S&S Premium Tappets; CNC Ported Heads; SE Wide Band Auto-Tuning Module; SE Pro Super Tuner; SE High Flow Street Cannon Exhaust; SE A&S Clutch Kit; Rekluse Centrifugal Clutch Pack; Dipstick Temp Gauge; S&S Stealth Air Cleaner; Yuasa GYZ Battery, 1.4 kW Starter; Amsoil; Mighty Might Cooling Fans & Accy Switch; GMR Compensaver; Pingel Shifter Shaft; High Output Charging System; SE Spark Plugs & Wires
    Handling: Cartridge Fork Dampening; Amsoil Suspension Oil; 18" Front Wheel; Floating Brake Rotors; EBC HH Brake Pads; Dunlop American Elite Tires; Ohlins HD 773 Shocks
    Comfort: Police Solo Saddle with Coil-Over Suspension; Extended Reach Footboards; SoftBrake 1 Extended Brake Lever & Reduced Reach Clutch Lever; Extended Shift Levers; Fairing Air Deflectors; Freedom 14" Windshield; Klock Werks Ergo Up Bars; Get-A-Grip Hand Grips; Kuryakyn Magnum Plus Mirrors
    Infotainment: Ultra Tank Console with Headset Connection & CVO Insert; Hidden Radio Antenna; GPS Map Update
    Luggage: Four Point Docking Hardware; Solo Tour-Pak Mounting Rack; King Tour-Pak and Lining; Tour-Pak Wall Organizer; Premium King Travel-Pak; Chopped Backrest Pad; Premium Saddlebag Travel-Paks; Innovative Storage Solutions Tool Bags; Saddle Bag Guard Bags & Bottle Holders
    Appearance: CVO Black Gauges; Carbon Fiber Gauge Panel; De-badged Gas Tank; Skull Emblems over Fairing Mirror Holes; Diamond Engineering 12 Point Engine Screws; Allen Hole Plugs; Piston Muffler End Caps
  4. #14
    Founding Member chaderick's Avatar
    Join Date
    Nov 2014
    City
    New Vienna
    State
    Ohio
    Posts
    346
    I have Avon iso grips on mine, I'm very pleased so far
    Chad
    2014 FLHXS Vivid Black
    21 inch Chrome reinforcer
    SE Ventilator Air Cleaner
    Vance & Hines FP3 Fuelpak
    D&D fat cat w/ ghost pipe
    Yaffe 10" Monkey Bars
    Klock Werks 6.5 windshield
    Klock Werks Slicer front fender
    JW Speaker EVO 2 LED headlight
    Custom Dynamics LED
    Top Shop Viper bags
    Topshop CVO Kingsman fender
    Topshop side covers
    Sound digital amp.
    Crescendo 6.5, ST25 horns
    Iron 57 Lids
    JNR designed air ride
    Dakota Digital Gauges
    Jh Choppers accessories
  5. #15
    Founding Member BluesBelly's Avatar
    Join Date
    Oct 2014
    City
    Alexandria
    State
    Minnesota
    Posts
    919
    Grips are the first thing that gets changed when I get an HD. The stockers are just too small in diameter and my hands cramp. I installed Get-A-Grips last fall when I got my SG and have about 3K on them. I really like them! Would buy them again. Different strokes I guess!
    Blues
    2014 FLHX Brilliant Silver Pearl
    Fuel Moto air intake
    2014 CVO mufflers
    13" Ultra air shocks
    Custom Dynamics LED's
    10" dark tint Wind Vest
    Fairing mount air deflectors
    Fork Fangs
    Saddlebag guards
    HD Detachable sissy bar, back rest,
    and detachable Air Wing rack
    6.5 Boom stage I speakers
    Midframe air deflector.
    Soft Brake 2" Extended brake pedal and 1.5" shift arm
    HD 1" extended swept floorboard pans with 1" outward extensions
    Grips, 4" mini passenger boards, & much Misc
  6. #16
    Founding Member hevyrockerdk's Avatar
    Join Date
    Aug 2014
    City
    Orlando
    State
    Florida
    Posts
    356
    I went with HD black diamond grips on mine. The sole reason for that is because they are made of metal with a very small amount of rubber. Rubber has a tendency to melt down here, and the stockers are the worst offenders.
    2014 Vivid Black FLHX
    LED Run/Turn/Brake light upgrade
    Black Diamond HD Grips
    7" Wind Splitter Windshield
    Multi Color LED engine bay lights
  7. #17
    Senior Member shortguy's Avatar
    Join Date
    Jul 2014
    City
    SV
    State
    Arizona
    Posts
    130
    i have the deep cut from Ness as well and love them
    ~2014 SGS~ http://streetglide.com/showthread.ph...s-14-SGS-Build
    WO577 12.5" Bars/Deep Cut Grips/HD edge cut levers/hidden antenna/Diamond micro4/Hertz SV 165.1/Hertz ST25/CD- LED turn/signal/plasma rods/tri-bar/FP3/Daymaker/HD 7" windshield/headlight trim/Ness beveled AC matching horn kit/JNR air ride/Fullsac/RCX down slash pipes/Ness dash insert, fuel door, ignition cover/monotubes/mustache bar/curved plate frame/SE585 cams/HD valve springs/adj pushrods/JH Choppers parts
  8. #18
    Founding Member flatlander's Avatar
    Join Date
    Apr 2014
    City
    Marion
    State
    Illinois
    Posts
    541
    GRIPS ??? opinions.....
    Another with A. N. deep cut same color as Spazz
    They have no company logo on them that I have seen.
    I can be rolling down the highway with cruise set and twist the throttle to pass With out even having to fully grab the grip to do so.
    Love my A. N. grips.
    Get on your Bad Motor Scooter and Ride
    16 Street Glide Special Vivid Black
  9. #19
    Putting black Deep Cuts on mine with the bar change in a week or two. They are very nice feeling grips. And well made. But I haven't ride with them yet.
  10. #20
    Join Date
    Jul 2014
    City
    Long Island
    State
    New York
    Posts
    293
    Update regarding grips...
    I went with the Arlen Ness "deep cut - comfort grips" ... Installed them today & took an hour ride... Very pleased & they are exactly what I was hoping they would be... Easy install - larger diameter grip comparred to factory & larger diameter than the HD "get a grips"....
    Highly recommended...
    Chris
    2014 FLHXS
    Vivid Black
Posting Permissions
  • You may not post replies
  • You may not edit your posts
