Results 1 to 7 of 7
  1. #1
    Prospect
    Join Date
    Sep 2015
    City
    Milwaukee
    State
    Wisconsin
    Posts
    Streetglide in Bahrain (battery won’t keep charge)
    I have a new battery , and it wont keep charge . I have to recharge it every 2 weeks or so. Any suggestions ?
  2. #2
    Founding Member hevyrockerdk's Avatar
    Join Date
    Aug 2014
    City
    Orlando
    State
    Florida
    Posts
    140
    Could be a sub-par battery... Try a new one. If that one produces the same results, I would start looking at electrical systems to see if anything is drawing excessive current while the bike is powered off.
    Sent from my HTC One M9
    2014 Vivid Black FLHX
    LED Run/Turn/Brake light upgrade
    Black Diamond HD Grips
    7" Wind Splitter Windshield
    Multi Color LED engine bay lights
  3. #3
    Founding Member Gunner's Avatar
    Join Date
    Jul 2014
    City
    Ocean City
    State
    Maryland
    Posts
    62
    Are you keeping it on a battery tender when not ridding ? If not, that might be your problem.
    2014 FLHXS- 84.3 HP 106.2 Torque
    Bassani True Duals / 4" Rineharts
    ThunderMax Wave Tune / K&N Air Charger
    Softbrake Extended brake pedal.
    Lepera DaddyLonglegs Seat
    Wild 1 12.5" Bars
  4. #4
    Senior Member corey45k's Avatar
    Join Date
    Aug 2015
    City
    Mount Wolf
    State
    Pennsylvania
    Posts
    98
    What is your alternator putting out?
    2009 FLHX - Pewter Pearl
    Python Rayzer 2-1 Black
    Vance and Hines Fuelpak
    Vance and Hines VO2 Naked Air Intake
    15" Burly Black Bagger Bars
    Burly Black Cable Kit
    Black Wide Blade Levers
    Black Avon Air-SS Grips
    JW Speaker 8700 Evolution 2
    Blacked Out Headlight Rings
    Blacked Out Windshield Trim
    Blacked Out Air Intake Cap
    Blacked Out Cowbell
    Iron Cross Audio Upgraded HK w/In-Fairing Antenna
    Pushbutton Fuel Door
  5. #5
    Senior Member BluesBelly's Avatar
    Join Date
    Oct 2014
    City
    Alexandria
    State
    Minnesota
    Posts
    120
    Quote Originally Posted by rjruiz1 View Post
    Welcome.
    First question: How old was the old battery and did it keep a charge or why did you replace it.
    Second question: Did you do a drawdown test on the new battery to determine if it is a good battery?
    2014 FLHX Brilliant Silver Pearl
    Fuel Moto air intake
    2014 CVO mufflers
    13" Ultra air shocks
    Custom Dynamics LED's
    10" dark tint Wind Vest
    Fairing mount air deflectors
    Fork Fangs
    Saddlebag guards
    HD Detachable sissy bar, back rest,
    and detachable Air Wing rack
    6.5 Boom stage I speakers
    Midframe air deflector.
    Soft Brake 2" Extended brake pedal and 1.5" shift arm
    HD 1" extended swept floorboard pans with 1" outward extensions
    Grips, 4" mini passenger boards, & much Misc
  6. #6
    Bones
    Guest
    Double check for a loose battery connection. Make sure they are clean and tight.
  7. #7
    Join Date
    Aug 2015
    City
    Winter Park
    State
    N/A
    Posts
    Parasitic draw is common with multiple electronics.. Any addons and a load test would be a place to start
Posting Permissions
  • You may not post replies
  • You may not edit your posts
