Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Member D94's Avatar
    Join Date
    Jan 2015
    City
    Northern
    State
    New Jersey
    Posts
    93
    Careful cutting out the green connector. It's 50/50 that you will have no problems. Just as easy to get the CVO Tgs. No green connector, easy,peasy. Just make sure you have your HD dealer switch the pins to male to fit your plug.
    2015 FLHXS Black Denim
    LA Choppers Stage 1 A/C
    S&S Power Tune Duals ( Black )
    RC Components 4" Slip Ons
    JW Speaker 8700 Evo 2 LED Headlight- Black
    Paul Yaffe 12" Monkey Bars
    Avon Velvet Spike Grips- Black
    Mustang Wide Tripper Solo Seat w/ Diamond Stitch
    Dave Perewitz Diamond Stitch Fender Bib
    Custom Dynamics LED Ringz and Tri Bar (Smoke)
    V&H FP3 FuelPak
    Arc Audio Moto 600.4
    JBL GTO629 ( Fairing )
  2. #12
    Administrator Mojo's Avatar
    Join Date
    Dec 2013
    City
    Nashville,
    State
    Tennessee
    Posts
    6,093
    Man, That's a good video tutorial!
    2017 FLHXS Velocity Red Sunglow
    Milwaukee Eight 107 l Stage 1 l V&H FP3 Tuner l SE air cleaner l Cobra 909 Slip ons l Stage ll Torque
    HD Hard Lowers
    l 4 Point detach l Low Backrest l ClearView Shield l Fairing wings l Fork deflectors
    Custom Dynamic Fr & Rr LED's & Plasma Rods, Halo headlight l CVO seat l Tri-Bar / Brake Taillight
    PSALM 91
    Whoever dwells in the shelter of the Most High will rest in the shadow of the Almighty.
  3. #13
    Prospect
    Join Date
    Aug 2015
    City
    Macomb
    State
    Illinois
    Posts
    24
    50/50 chance on eliminating the green connector! Thats not very good odds. This job is getting kind of scary! Maybe the CVO harness would be a better way to go.
    No one has commented on the elimination of the heated grip connectors yet.
    My next attempt will be using the mig welding wire. Someone posted a real good tip on pulling the wire
    through to start. That makes good sense.
    I can be methodical but my patience can be short sometimes. Just don't want to give up and have to pay someone to do this for me. That money could be better spent.
  4. #14
    Founding Member GreetSlide808's Avatar
    Join Date
    Feb 2014
    State
    Hawaii
    Posts
    395
    Quote Originally Posted by pfnork View Post
    I removed the heated connector in the bar. I live in Hawaii and I knew there was no chance of me ever using heated grips. It made the wire run a lot easier.
    2014 SG
    Rinehart 4" slipons w/Merge tips
    header cat delete
    SE air cleaner
    Power Vision auto tuner
    Custom Dynamics LED turn sigs
    Custom Dynamics LED Moonshinez
    Custom Dynamics Plasma Rods
    Advan Black Lower Fairing
    12" Wild 1 Reaper Bagger Bars
    Cycle Sounds Amp w/BT355 LL
    2- 6.5" CS Speakers
    2- 6.5" Polk Audio MM 651 Speakers
    JW Speaker Evo2 LED Headlight
    Amsoil in all 3 holes
    Mutazu saddlebag extensions
    Klockwerks Flare shield (5")
    Danny Gray Speedcradle solo seat
  5. #15
    Senior Member El Chapo's Avatar
    Join Date
    Aug 2015
    City
    Safford
    State
    Arizona
    Posts
    132
    We cut the heated grip wiring off of my buddies bike and it help with the pull and no problems with short or codes. CUT IT OFF !
  6. #16
    Prospect
    Join Date
    Feb 2016
    City
    New Egypt
    State
    New Jersey
    Posts
    21
    Used Namz wire extension kits in my 13" prime apes that I just installed. Pulling the wires thru can be a little tricky but used some water soluble lube used for pulling home wiring thru conduit. Got everything pulled thru even the heated grip plug with very little trouble.
  7. #17
    Prospect Black Label's Avatar
    Join Date
    Feb 2016
    City
    Walterboro
    State
    South Carolina
    Posts
    21
    Installing 12" Monkey bars on the SG. Watched the video many times. Am at the wire pull stage.
    First attempt failed. Very bad words were spoken, not my finest hour!
    If I never plan to use heated grips, can I clip off the connecters on the cable?
    The green connector will be eliminated (soldered and shrink-wrapped).
    Just want to eliminate as much as possible.
    The trick to pulling those wires is wire lube from your local hardware store and when they get tough to pull just be patient and work them back and forth a couple of times and they will slip right through.
  8. #18
    Prospect
    Join Date
    Mar 2017
    City
    Penrose
    State
    Colorado
    Posts
    19
    I am having the same exact issue. I spoke with the stealership and they advised me to purchase part No. 32305-08A. Is this the correct one since 32310-08 only has two red, two black, and two white wires?
    I think I may damage the wires on the stock tbw when pulling the wires. This is why I am thinking of purchasing the new one.
  9. #19
    Prospect
    Join Date
    Jun 2015
    City
    inez ky
    State
    Kentucky
    Posts
    just cut all the plugs off and solder and use heat shrink and you'll be just fine only use the plugs that comes threw the bars
  10. #20
    Prospect
    Join Date
    Mar 2017
    City
    Penrose
    State
    Colorado
    Posts
    19
    Got it all finished. Rode all day Tuesday, about 350 miles. Felt great no numbness and looks great. Thanks for all the advice. You guys rock!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
