Results 1 to 8 of 8
  1. #1
    Senior Member t8ness's Avatar
    Join Date
    Aug 2015
    City
    Riverside
    State
    California
    Posts
    228
    Brake lights/front brake lever
    My front brake lever isnít activating my brake lights, and thus not shutting off the cruise control (rear brake control works fine). Is the lever bad or is that some sorta fuse? 2014 Street Glide
    Thanks
    2014 Street Glide Vivid Black ABS
    Matching Inner Batwing Fairing
    Full Streamliner Kit
    Boom! Audio Hidden AM/FM/WB Antenna
    Scripted Custom Gear Shift Linkage
    Harley Davidson Chrome Daymaker
    Chrome Forks
    Stage 1 Download
    Harley Davidson Screaming Eagle Street Cannons with Screamin' Eagle Script 4 in. End Caps
    Screamin' Eagle Agitator Extreme Billet Air Cleaner Kit
    Infinity Kappa 62.11I 150W 6.5-Inch
    Rockford Fosgate PBR300X2 Punch 300-Watt 2-Channel Amp
    CD LED Cluster Inserts
  2. #2
    Did you change the levers ? If you did. And did not do it properly you broke the switch inside the switch housing.
  3. #3
    Join Date
    Aug 2015
    City
    Riverside
    State
    California
    Posts
    228
    Quote Originally Posted by Dr LEN View Post
    Did not change levers. Still stock
    Chrome Forks
    Stage 1 Download
  4. #4
    Prospect
    Join Date
    Mar 2016
    City
    Norwich
    State
    N/A
    Posts
    23
    Could be contaminated/ degraded brake fluid. I went through a similar drama on a LowRider a while back, a complete flush and change sorted it. I now change brake and clutch fluids every two years for peace of mind with no problems since.
  5. #5
    Join Date
    Aug 2015
    City
    Riverside
    State
    California
    Posts
    228
    Quote Originally Posted by Tbird View Post
    Even though the brakes still function properly? I have no issues stopping. Iíll look into this as well too
    Chrome Forks
    Stage 1 Download
  6. #6
    Senior Member LiveToGlide's Avatar
    Join Date
    Aug 2014
    City
    Linden
    State
    Michigan
    Posts
    114
    I had the same issue and HAD replaced a switch in side the housing.
    Sent from my XT1650 using Tapatalk
    USAF (Retired)
    2014 FLHXS Vivid Black - every time I walk in the garage
    SE Street Cannons w/Slash Tips
    8" Freedom Shield
    4 Pt Docking, Detachable Sissy Bar & Luggage Rack
    Chrome Saddlebag Guards, Fairing Trim, Passenger Floor Boards, Fork Wind Deflectors
    Sundowner Seat
    Rider Adjustable Back Rest
    Saddlemans 3800EX Touring Bag
  7. #7
    Join Date
    Aug 2015
    City
    Riverside
    State
    California
    Posts
    228
    Turns out the lever separated from grip where but to activate is. Just readjusted and that fixed problem
    Chrome Forks
    Stage 1 Download
  8. #8
    Senior Member El Chapo's Avatar
    Join Date
    Aug 2015
    City
    Safford
    State
    Arizona
    Posts
    112
    Guarantee that small switch is broke under your brake lever. Easy fix. I think like 20 bucks or so.
    2014 Street Glide Charcoal Pearl, Vance & Hines power duals, Rinehart Racing 4" slip-ons, Vance & Hines VO2 air intake, Vance & Hines FP-3 programmer
    Yaffe 12" bars, Rockford Fosgate amp, Polk Audio speakers, LRS shield, Michelin Commander II, 4 point docking with HD backrest. HD luggage rack. Performance Machine contrast cut trim. Removable color match tour pak.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
