Results 1 to 4 of 4
Thread: forks locked!!!
  1. #1
    Prospect
    Join Date
    Apr 2018
    City
    edgewater bc
    State
    N/A
    Posts
    forks locked!!!
    Changing out my 12" bars for some 20"s. have everything apart, fitting the bars before off to chromers and my forks locked on their own! ignition is all apart and hadn't given me an issue until i was about to pack up for the night and the front just swung over to the left and the forks locked. how can i release the lock without the ignition in so that i can change the bushings?
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    489
    Quote Originally Posted by jared View Post
    Bummer. You need to get an ignition lock alignment tool or ...... if you can solve a Rubik's Cube, you may have the skills to re-align it with a screwdriver.
    2014 FLHXS: Sand Camo Denim
    H-D Parts Except as Noted: updated 07-Jan-2019
    Front Lighting: Illuminated Hand Control Switches; Auxiliary Lamp Kit; Norman 3000K LED Lamps W/PAR 36 Amber Lens Covers; JW Speaker Evolution II LED Headlight; Amber LED Turn Signals
    Rear Lighting: LED Light Bar; Tri-Bar Fender Brake Light; Tour-Pak and Saddlebag Run/Brake/Turn LED Lamps
    Chrome: Fork Sliders & Covers; Axle Spacer; Fairing Skirt; Curved License Frame; Classic Timer Cover; Docking Point Covers; Windshield Trim; Rear Saddlebag Guards; Radio Trim; Stealth Tour-Pak Rack; Tour-Pak Lamp Trim; Smooth Horn Cover; Saddlebag Hinge Covers; Landmark Fat Round Shift Linkage; Klock Werks Flush Front Axle; Inner Primary Housing; Solenoid Cover; Chopped Engine Guard; Front Engine Mount & Link; Arlen Ness Smooth A/C Cover; Oil Cooler Protection Screen; Kuryakyn Fender Accents and Trim
    Security: Smart Siren II; Brukus TourPack Bullet Secure; Reda Saddlebag Locks; FOBO Tire Pressure Monitors; V-Twin Metal Valve Stems; Micro Start Kit W/Harness & Tire Inflator; Fuel Door Lock; Abus 7000 Disc Lock Alarm
    Engine: 103"; Line2Line Coated Stock Pistons; Andrews 57H cam; S&S Premium Tappets; CNC Ported Heads; SE Wide Band Auto-Tuning Module; SE Pro Super Tuner; SE High Flow Street Cannon Exhaust; SE A&S Clutch Kit; Rekluse Centrifugal Clutch Pack; Dipstick Temp Gauge; S&S Stealth Air Cleaner; Yuasa GYZ Battery, 1.4 kW Starter; Amsoil; Mighty Might Cooling Fans & Accy Switch; GMR Compensaver; Pingel Shifter Shaft; High Output Charging System; SE Spark Plugs & Wires
    Handling: Cartridge Fork Dampening; Amsoil Suspension Oil; 18" Front Wheel; Floating Brake Rotors; EBC HH Brake Pads; Dunlop American Elite Tires; Ohlins HD 773 Shocks
    Comfort: Police Solo Saddle with Coil-Over Suspension; Extended Reach Footboards; SoftBrake 1 Extended Brake Lever & Reduced Reach Clutch Lever; Extended Shift Levers; Fairing Air Deflectors; Freedom 14" Windshield; Klock Werks Ergo Up Bars; Get-A-Grip Hand Grips; Kuryakyn Magnum Plus Mirrors
    Infotainment: Ultra Tank Console with Headset Connection & CVO Insert; Hidden Radio Antenna; GPS Map Update
    Luggage: Four Point Docking Hardware; Solo Tour-Pak Mounting Rack; King Tour-Pak and Lining; Tour-Pak Wall Organizer; Premium King Travel-Pak; Chopped Backrest Pad; Premium Saddlebag Travel-Paks; Innovative Storage Solutions Tool Bags; Saddle Bag Guard Bags & Bottle Holders
    Appearance: CVO Black Gauges; Carbon Fiber Gauge Panel; De-badged Gas Tank; Skull Emblems over Fairing Mirror Holes; Diamond Engineering 12 Point Engine Screws; Allen Hole Plugs; Piston Muffler End Caps
  3. #3
    Senior Member
    Join Date
    Jan 2016
    City
    North judson
    State
    Indiana
    Posts
    Ive done it with a screwdriver...... but bought the tool so I wont have to do that again! Lol chris
  4. #4
    Founding Member azglocker's Avatar
    Join Date
    Dec 2015
    City
    Gilbert
    State
    Arizona
    Posts
    320
    There's a trick I learned when I messed up my switch alignment (in the parking lot, at work, because I wanted to graphite lube the assembly).
    It may look like the lobes on each side of the switch are the same, but they are not. One side is larger. With that in mind, you should be able to align everything with a screwdriver and a light and get it all in the position you want (I recommend unlocked/off).
    2018 Street Glide, Wicked Red.
    SE stage 1
    Mustang seat
    LEDs!
    daily driver. living in AZ, it's always riding season!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
