Results 1 to 5 of 5
  1. #1
    Prospect
    Join Date
    Sep 2017
    City
    Highland
    State
    Indiana
    Posts
    14
    Yaffe 12" monkey bar
    So I've used the search bar and found different, conflicting info. 12" yaffe monkey bars, do i need wiring extensions. I understand stock cables will need to be rerouted.
  2. #2
    Founding Member TomA's Avatar
    Join Date
    Apr 2014
    City
    Battle Mountain
    State
    Nevada
    Posts
    3,126
    There is a wiring harness you extend I think just to make it easier. Some have just stretched the stock one and got away with it. You should be able to look up some of the old threads on here for the part number. I did 16s so I had to replace or add onto everything.
    2014 Mysterious Red Sunglo
    Stage 1 D&D Boss Fat Cat 2-1 exhaust FP3 tuner
    JW Speaker E2, Custom Dynamic running and tails, 8 plasma rods
    Soundz Customz level 5 Carbon Iron series, 5x7 lids
    Color matched inner fairing and King tour pack with lowers
    Fork fangs, Fairing deflectors, REDA bag bolts
  3. #3
    Founding Member azglocker's Avatar
    Join Date
    Dec 2015
    City
    Gilbert
    State
    Arizona
    Posts
    528
    I needed extensions on my 14. The stock wires ended just inside the bars iirc. Hydro lines were just long enough.
    2018 Street Glide, Wicked Red.
    SE stage 1
    Mustang seat
    LEDs!
    daily driver. living in AZ, it's always riding season!
  4. #4
    Administrator Spazz's Avatar
    Join Date
    Feb 2014
    City
    Reno
    State
    Nevada
    Posts
    5,012
    yes... you NEED wiring extensions... but thats it... no cables... just cut your zipties off the triples. I recommend 8" extensions just to give you a little more than needed and you're not fighting anything.... its not any more money for longer exentions... fyi
    2015 FLTRXS 120ST 'RAVEN'
    D&D Boss Boarzilla | PowerVision and Target Tune | Chisel Extreme AC|Chrome Enforcer Wheels and Pulley
    Polished rotors|14" F47 Malo Bars|AN Deep Cut Grips and HD chrome levers | Chrome Sliders
    CD Dynamic Ringz LED's | Nasty Baggers Shift Linkage | Legacy Baggers Grill Medallions, Dash and Latch Custom Inserts
    Topshop 4.5" OEM Bags and CVO Minsiter Fender | Soundz Audio( 6 speakers )--SC4.100 amp, (4)Carbon 65's and (2)Iron 57's in the lids
  5. #5
    Member Lammas's Avatar
    Join Date
    Jan 2018
    City
    Rigby
    State
    Idaho
    Posts
    54
    I just did a set of 12" Yaffe Monkey Bars for a friend of mine. He rides a '15 FLHXS. I needed the wiring harness extension. Hydraulics were no problem.
    2014 FLHXS Black Denim & Chrome
    Legends Suspension. Axeos & Revo-A's
    Coastal Moto Largo Wheels 21/18 w/Commander IIs.
    21" Tire Hugger Level Fender from Factory Match
    Chrome Front End
    Road Six 13" Holy Roller Bagger Bars
    Kuryakyn Grips & Levers
    Freedom Shields 8" in Dark Grey
    Screaming Eagle Street Cannons
    HogWorkz Halo Maker LED Headlight
    HD Auxiliary Light Kit w/HogWorkz Halo Maker LED's
    Custom Dynamics Bullet Ringz, LED Saddle Bag Lamps & LED Tri-bar
    Custom Dynamics Magic Strobes
Posting Permissions
  • You may not post replies
  • You may not edit your posts
