Results 1 to 7 of 7
  1. #1
    Prospect
    Join Date
    Mar 2018
    City
    LEES SUMMIT US US
    State
    Missouri
    Posts
    4
    2018 SGS Stage IV on steroids
    I purchased a 2018 Cherry Red Special about 5 months ago, awesome bike and added the stage 4 with SE slip ons with hopes of hitting some good dyno numbes BUT with having to use only screaming eagle aftermarket parts and the SE tune it is not getting the numbers, I have now switched the cam out to a Woods 999 night prowler (Full Race) with RC true duals headers, sounds awesome but I have taken the bike back to the dealer twice for dyno tuning with disappointing results as they are lost with no more than 117hp, we did get a baseline from Dyno-Jet which I had the dealer re-set to as the tune they put on was horrible and about burnt my leg from heat, I had a independent who tuned it to 130 hp and it ran awesome but they had it knocking from too much timing and blowing black smoke it was so rich, again back to the dyno jet baseline, sooo now I'm looking at the dyno-jet target pro auto tune and am looking for any advice , will this system tune my engine with the drastic changes from stock and/or where to take the bike in/around KC, Help Im lost
    2018 SGS
    107 upgraded to Stage IV 114cu
    CNC Ported Heads
    Perf Valve springs
    64 MM Throttle Body
    High Flow Injectors
    4.075 Cylinders
    11:1 compression
    HP Pistons, Rings
    Woods 999 Cam
    S&S Lifters
    SE cam Bearings
    SE HP Tappets
    HP Clutch pack & Springs
    RC True Duals
    SE Pipes
  2. #2
    Founding Member TomA's Avatar
    Join Date
    Apr 2014
    City
    Battle Mountain
    State
    Nevada
    Posts
    1,858
    I feel your pain having a hard time getting my winter build tuned. I will get it done one way or another but I'm running a little lean also so trying to fix that with the power vision tuner auto tune and sending data to Fuel Moto.
    2014 Mysterious Red Sunglo
    Stage 1 D&D Boss Fat Cat 2-1 exhaust FP3 tuner
    JW Speaker E2, Custom Dynamic running and tails, 8 plasma rods
    Soundz Customz level 5 Carbon Iron series, 5x7 lids
    Color matched inner fairing and King tour pack with lowers
    Fork fangs, Fairing deflectors, REDA bag bolts
  3. #3
    Prospect
    Join Date
    Oct 2014
    City
    Oriskany
    State
    New York
    Posts
    You need to put a zipper cam 468 and find someone good to tune it, I got 118.4 HP and 134.56 Tq with this set up on a 2017 RGS
  4. #4
    Join Date
    Jun 2017
    City
    pembroke pines
    State
    Florida
    Posts
    55
    Thats good advice^^
  5. #5
    Prospect
    Join Date
    Mar 2018
    City
    LEES SUMMIT US US
    State
    Missouri
    Posts
    4
    Modifications
    What have you had done to the bike other than the cam to make those numbers
  6. #6
    Join Date
    Jun 2017
    City
    pembroke pines
    State
    Florida
    Posts
    55
    Ill be nice..
  7. #7
    Member Bafflingbs's Avatar
    Join Date
    May 2015
    City
    Owings
    State
    Maryland
    Posts
    46
    You true duals are hurting you, as well as your over sized throttle body. Bigger doesn’t mean better sometimes. I’ve got a 110 twin cam, with a ported 50mm tb., and I’m making 117/130. You should be closer to 130 squared. (Or more) I’ve also got a Fat Cat 2-1
    2015 FLHXS Morocco Gold Pearl Fuel Moto 110”- 117hp/130tq, D & D Fat Cat, Woods 999-6A cams, level “B” heads, 10.5/1 CP pistons, Thundermax, Ported 50mm throttle body, Feuling 5.3 injectors, Darkhorse Man-o-War crank, AIM VPC w/ Kevlar plates, Zippers cam plate with Feuling oil pump, Bad Dad tour pack, Top Shop rear fender and saddlebags, KW front fender, Arlen Ness Hot Legs,” Öhlins HD159’s and Progressive Monotubes 10” L.A. Choppers “Twin Peaks”
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
