Results 1 to 4 of 4
  1. #1
    Prospect Flodaddy14's Avatar
    Join Date
    Nov 2017
    City
    Fort Worth
    State
    Texas
    Posts
    4
    How to use 2ohm Infinnity Kappa speakers with RF PBR300X4 4ohm amp
    Is there anyway to use my RF PBR300X4 4ohm amp with 2ohm speakers ? Or does anyone have suggestions on a good 4 ohm 6.5 speaker .
    2012 Street Glide
    Denim Black
    SE Extreme Billet Ventilator Air Cleaner w K & N
    Rinehart slip ons
    Dyno Jet w Power Vision tune , Stage I
    Rockford Fosgate PBR300X4 amp
    Rockford Fosgate 6.5 punch speakers
    Freedom 7" medium tint W/S
    Michelin Commander II tires
    Luggage Guards
    Mid Frame Air Deflector
    Willie G derby cover,console door,timing cover & axle nut covers
    Forward & Rear LED lighting , Custom Dynamics
    4 point docking
    HD backrest.
    HD luggage rack.
  2. #2
    Prospect
    Join Date
    Feb 2018
    City
    Cleveland
    State
    Ohio
    Posts
    Bump.
    I want to do the same. Add 2ohm Infinnity Kappa's
    in lower fairing and J&M 7" Rockers in the fairing (2 ohm as well).
    Can I wire them in series to make 4 ohms for the PBR300X4 amp?
  3. #3
    Prospect
    Join Date
    Jun 2019
    City
    Kohler
    State
    Wisconsin
    Posts
    Yep wire them in series ,,,this site has everything about wiring and watts/loads and ohms its great ,,,Good luck
    https://geoffthegreygeek.com/
  4. #4
    Administrator Spazz's Avatar
    Join Date
    Feb 2014
    City
    Reno
    State
    Nevada
    Posts
    2,116
    This is correct...
    If you take 2 2ohm speakers and wire them in series... + to -.. + from one speaker to amp and - from other speaker to amp, you will double the load to 4 ohms.
    2015 FLTRXS 120ST 'RAVEN'
    D&D Boss Boarzilla |TTS MasterTune | Chisel Extreme AC|Chrome Enforcer Wheels and Pulley
    Polished rotors|14" F47 Malo Bars|AN Deep Cut Grips and HD chrome levers | Chrome Sliders
    CD Dynamic Ringz LED's | Nasty Baggers Shift Linkage | Legacy Baggers Grill Medallions, Dash and Latch Custom Inserts
    Topshop 4.5" Bags. Side covers and CVO Minsiter Fender | Soundz Audio--SS4.100 amp, DSP, (4)Carbon 65's and (2)Iron 69.2s
    Owner- RENO BAGGER AUDIO
Posting Permissions
  • You may not post replies
  • You may not edit your posts
