Results 1 to 3 of 3
Thread: Black out cost
  1. #1
    Founding Member Mandrew's Avatar
    Join Date
    Feb 2015
    City
    Middle of
    State
    Missouri
    Posts
    247
    Black out cost
    Went in to the local dealership this morning to get a service estimate to install blacked out rocker box housings, rocker box covers, cam cover, front engine mount, and pushrods.
    11 hours of labor. Oh my- that was quite a bit more than I expected. They said it was essentially the same work load as doing an engine kit. For anyone else that has changed out those pieces, does this match your experience?
    Mandrew
    2014 FLHXS
    Custom paint by CC CustomGraphics
    C&S Speed Shop tune
    SE heavy breather elite AC
    SE high flow exhaust
    Soundz Customz Level IV Audio
    Focal 165KRC speakers and Arc Audio KS125.2 Amp
    AirFx rear air ride
    HD premium low profile front
    Gloss black front fork
    HHI hidden front axle
    Xtreme Machine Launch from Coastal Moto
    Long ride shields
    Custom Dynamics turn signals and plasma rods
    HD hidden antenna
    Daymaker Headlight
    HD Garage Door Opener
    Corbin Classic Solo
  2. #2
    Senior Member CoHam's Avatar
    Join Date
    Dec 2016
    City
    Parker
    State
    Colorado
    Posts
    147
    That’s more than they need unless a beginner is doing it.
    They are not pulling the heads, changing the cylinders, pistons, and all those associated gaskets. They are not swapping out the cams, bearings or shims. To say that it is essentially the same workload as an engine kit is seriously overstating it.
    They need to pull the gas tank, rocker boxes, rockers, breather assembly, and pushrods. The cam cover and front mount is very quick and simple. If a professional shop spent 8 solid hours on it then I’d wonder how many beers they had at lunch.
  3. #3
    Join Date
    Feb 2015
    City
    Middle of
    State
    Missouri
    Posts
    247
    Thanks for the reply. I had reviewed all of the work steps in my service manual. Everything seemed to be in my comfort and skill level except for the rocker box housings- and doing that made me want to go ahead and do the pushrods as well.
    Iím going to check with other shops in the area. I want to swap the parts, but not for 11 hours of labor. I was legitimately expecting something in the 5-6 hour range.
    Mandrew
    2014 FLHXS
    C&S Speed Shop tune
    AirFx rear air ride
    Long ride shields
    HD hidden antenna
    Daymaker Headlight
    Corbin Classic Solo
Posting Permissions
  • You may not post replies
  • You may not edit your posts
