Results 1 to 6 of 6
  1. #1
    Prospect
    Join Date
    Mar 2019
    City
    Hyattsville
    State
    Maryland
    Posts
    7
    Deutsch HDT-48-00 Crimp tool
    I need to attach the Deutsch Crimps on to the wiring harness for the detachable luggage rack light kit I bought.
    Is this the tool to make that crimp?
    Thanks for your input.
  2. #2
    I donít think you need a crimp tool for those.
  3. #3
    I just use pliers.
  4. #4
    Member Dutchman17's Avatar
    Join Date
    Mar 2017
    City
    Cincinnati
    State
    Ohio
    Posts
    84
    The Harley part number is
    HD-42879 IMG_1159.jpgIMG_1160.jpg. I have attached photos. There is also a Packard Terminal Crimper part number HD-38125-7. I found both in my 2015 Electrical Diagnostic Manual HD-99497-15 I found both in section A on pages 25-27. Iím sure that you could check the manual for your year. Section A of the Electrical Diagnostic Manual covers the different tools and pins used on the connectors.
    2015 SGS; Stage 1;
    1inch Floorboard and passenger extensions;
    Cycle Solutions Ceramic True Dual Head-pipes;
    ThunderMax Tuner;
    4.5 inch RC Exhaust slip-on mufflers;
    LED rear tail lights; LED front turn signals/ running lights
  5. #5
    Join Date
    Mar 2017
    City
    Cincinnati
    State
    Ohio
    Posts
    84
    I probably didnít answer your question regarding the crimping tool. I canít find any additional information in the on line catalog for parts and accessories talking about special tools needed. It does look like the correct tool for the air wing lighting kit that I was able to find not sure if itís what you have. Hope this helps. Personally I would prefer to crimp wires used in connectors especially if you have to remove them later.
    2015 SGS; Stage 1;
    ThunderMax Tuner;
  6. #6
    Prospect
    Join Date
    Mar 2019
    City
    Hyattsville
    State
    Maryland
    Posts
    7
    Thanks for your reply. This was helpful.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
