Results 1 to 5 of 5
Thread: Fat front tire.
  1. #1
    Member El Chapo's Avatar
    Join Date
    Aug 2015
    City
    Safford
    State
    Arizona
    Posts
    64
    Fat front tire.
    So I am thinking about doing a fat front tire upgrade, I just think it looks badazz. My question is what would I have to change and how do those of you that have them like the way they handle ? If you have pics, please share them. I apologize if there is a thread already on this, I just can't find it.
    2014 Street Glide Charcoal Pearl, Vance & Hines power duals, Vance & Hines OS 450 Raiders slip-ons, Vance & Hines VO2 air intake, Vance & Hines FP-3 programmer
    Yaffe 12" bars, Rockford Fosgate amp, Polk Audio speakers, LRS shield, Michelin Commander II, 4 point docking with HD backrest. HD luggage rack. Performance Machine contrast cut trim. Removable color match tour pak.
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    434
    It will handle better and be more comfortable. Just put on take-off parts from an Electraglide. See eBay.
    If you have anti-lock brakes you need parts from a bike that has them.
    Your dealer can help.
    2014 FLHXS: Sand Camo Denim
    H-D Parts Except as Noted: updated 07-Jan-2019
    Front Lighting: Illuminated Hand Control Switches; Auxiliary Lamp Kit; Norman 3000K LED Lamps W/PAR 36 Amber Lens Covers; JW Speaker Evolution II LED Headlight; Amber LED Turn Signals
    Rear Lighting: LED Light Bar; Tri-Bar Fender Brake Light; Tour-Pak and Saddlebag Run/Brake/Turn LED Lamps
    Chrome: Fork Sliders & Covers; Axle Spacer; Fairing Skirt; Curved License Frame; Classic Timer Cover; Docking Point Covers; Windshield Trim; Rear Saddlebag Guards; Radio Trim; Stealth Tour-Pak Rack; Tour-Pak Lamp Trim; Smooth Horn Cover; Saddlebag Hinge Covers; Landmark Fat Round Shift Linkage; Klock Werks Flush Front Axle; Inner Primary Housing; Solenoid Cover; Chopped Engine Guard; Front Engine Mount & Link; Arlen Ness Smooth A/C Cover; Oil Cooler Protection Screen; Kuryakyn Fender Accents and Trim
    Security: Smart Siren II; Brukus TourPack Bullet Secure; Reda Saddlebag Locks; FOBO Tire Pressure Monitors; V-Twin Metal Valve Stems; Micro Start Kit W/Harness & Tire Inflator; Fuel Door Lock; Abus 7000 Disc Lock Alarm
    Engine: 103"; Line2Line Coated Stock Pistons; Andrews 57H cam; S&S Premium Tappets; CNC Ported Heads; SE Wide Band Auto-Tuning Module; SE Pro Super Tuner; SE High Flow Street Cannon Exhaust; SE A&S Clutch Kit; Rekluse Centrifugal Clutch Pack; Dipstick Temp Gauge; S&S Stealth Air Cleaner; Yuasa GYZ Battery, 1.4 kW Starter; Amsoil; Mighty Might Cooling Fans & Accy Switch; GMR Compensaver; Pingel Shifter Shaft; High Output Charging System; SE Spark Plugs & Wires
    Handling: Cartridge Fork Dampening; Amsoil Suspension Oil; 18" Front Wheel; Floating Brake Rotors; EBC HH Brake Pads; Dunlop American Elite Tires; Ohlins HD 773 Shocks
    Comfort: Police Solo Saddle with Coil-Over Suspension; Extended Reach Footboards; SoftBrake 1 Extended Brake Lever & Reduced Reach Clutch Lever; Extended Shift Levers; Fairing Air Deflectors; Freedom 14" Windshield; Klock Werks Ergo Up Bars; Get-A-Grip Hand Grips; Kuryakyn Magnum Plus Mirrors
    Infotainment: Ultra Tank Console with Headset Connection & CVO Insert; Hidden Radio Antenna; GPS Map Update
    Luggage: Four Point Docking Hardware; Solo Tour-Pak Mounting Rack; King Tour-Pak and Lining; Tour-Pak Wall Organizer; Premium King Travel-Pak; Chopped Backrest Pad; Premium Saddlebag Travel-Paks; Innovative Storage Solutions Tool Bags; Saddle Bag Guard Bags & Bottle Holders
    Appearance: CVO Black Gauges; Carbon Fiber Gauge Panel; De-badged Gas Tank; Skull Emblems over Fairing Mirror Holes; Diamond Engineering 12 Point Engine Screws; Allen Hole Plugs; Piston Muffler End Caps
  3. #3
    Join Date
    Dec 2016
    City
    Fenton
    State
    Missouri
    Posts
    58
    I believe you are referring to putting a rear tire on the front and not a 17" electraglide stock front, correct? I believe Yaffe came out with first and now sells a kit.
    2015 FLHX - LA Chopper's 10" bars w/heated grips, LA Chopper's Tru-Power 4" slipons with stock CAT in header, Ness Big Sucker A/C, V&H FP3 tuner.
  4. #4
    Founding Member TomA's Avatar
    Join Date
    Apr 2014
    City
    Battle Mountain
    State
    Nevada
    Posts
    1,604
    There are several companies selling kits to put the fat tires on now. I hear they ride and handle better but have not ridden one myself.
    2014 Mysterious Red Sunglo
    Stage 1 D&D Boss Fat Cat 2-1 exhaust FP3 tuner
    JW Speaker E2, Custom Dynamic running and tails, 8 plasma rods
    Soundz Customz level 5 Carbon Iron series, 5x7 lids
    Color matched inner fairing and King tour pack with lowers
    Fork fangs, Fairing deflectors, REDA bag bolts
  5. #5
    Member yegg's Avatar
    Join Date
    Sep 2015
    City
    Fairfax
    State
    Virginia
    Posts
    44
    Any updates to this El Chapo? I'm thinking of this too. My next service due is the 50k and the service manual calls for a fork rebuild. I have always wanted chromed lowers and am thinking this may be the time (excuse) for me to go with the fatty front.
    The two kits I am debating are the Bad Dad and the Native Baggers. I Like those because they are both bolt on. It also seems to me that if I go this route all that I will really need is a new set of springs (looking to upgrade and now seems to be the time) and fork oil.
    Elliott
    2015 SGS - Amber Whiskey
    Stage 1 - V&H Dresser Duals, CFR Slip Ons, RSD Clarity AC, and V&H FP3
    CD Bullet Ringz (Front)
    Accutronix Instigator rider boards
    Bad Dad Forward Control Kit with Toe Shifter
    Mustang LowDown Vintage Solo & low profile primary cover (vertically challenged)
    Kuryakyn Premium ISO Grips, Zombie Levers
    Kuryakyn Lower Triple Tree Wind Deflector
    HD 4-Point Docking Hardware, Rear Docking Hardware Cover Kit
    Klock Werks 6.5" Flare - Black
Posting Permissions
  • You may not post replies
  • You may not edit your posts
