Results 1 to 5 of 5
  1. #1
    Prospect purvistechie's Avatar
    Join Date
    Jul 2015
    City
    BLOOMINGTON
    State
    Minnesota
    Posts
    6
    2019 CVO Exhaust options to keep "stock look"
    I just purchased a new 2019 Black Forest CVO Street Glide. I found that it has "Black Chrome" heat shields on the exhaust. In order to keep these heat shields and that Black chrome look, the options on exhaust are limited. I has them install Kirker Stout which sound good, but are quite a bit quieter than my 2015 with the same exhaust. Granted, I had full sac headers on my prior bike. Now, to stay compliant with Harley, I did not change the stock headers.
    Will the Kirker, the stock heat shields can stay in place and they even put on the stock CVO tips! Love the look.
    So, to my question. Are there other options that anyone knows of that would keep the stock Black Chrome look all the way back to the tips that has a little more volume while not changing the headers in order to stay warranty compliant?
    THANK YOU!!
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    468
    This exhaust system works great: screamin-eagle-high-flow-exhaust-system
    2014 FLHXS: Sand Camo Denim
    H-D Parts Except as Noted: updated 07-Jan-2019
    Front Lighting: Illuminated Hand Control Switches; Auxiliary Lamp Kit; Norman 3000K LED Lamps W/PAR 36 Amber Lens Covers; JW Speaker Evolution II LED Headlight; Amber LED Turn Signals
    Rear Lighting: LED Light Bar; Tri-Bar Fender Brake Light; Tour-Pak and Saddlebag Run/Brake/Turn LED Lamps
    Chrome: Fork Sliders & Covers; Axle Spacer; Fairing Skirt; Curved License Frame; Classic Timer Cover; Docking Point Covers; Windshield Trim; Rear Saddlebag Guards; Radio Trim; Stealth Tour-Pak Rack; Tour-Pak Lamp Trim; Smooth Horn Cover; Saddlebag Hinge Covers; Landmark Fat Round Shift Linkage; Klock Werks Flush Front Axle; Inner Primary Housing; Solenoid Cover; Chopped Engine Guard; Front Engine Mount & Link; Arlen Ness Smooth A/C Cover; Oil Cooler Protection Screen; Kuryakyn Fender Accents and Trim
    Security: Smart Siren II; Brukus TourPack Bullet Secure; Reda Saddlebag Locks; FOBO Tire Pressure Monitors; V-Twin Metal Valve Stems; Micro Start Kit W/Harness & Tire Inflator; Fuel Door Lock; Abus 7000 Disc Lock Alarm
    Engine: 103"; Line2Line Coated Stock Pistons; Andrews 57H cam; S&S Premium Tappets; CNC Ported Heads; SE Wide Band Auto-Tuning Module; SE Pro Super Tuner; SE High Flow Street Cannon Exhaust; SE A&S Clutch Kit; Rekluse Centrifugal Clutch Pack; Dipstick Temp Gauge; S&S Stealth Air Cleaner; Yuasa GYZ Battery, 1.4 kW Starter; Amsoil; Mighty Might Cooling Fans & Accy Switch; GMR Compensaver; Pingel Shifter Shaft; High Output Charging System; SE Spark Plugs & Wires
    Handling: Cartridge Fork Dampening; Amsoil Suspension Oil; 18" Front Wheel; Floating Brake Rotors; EBC HH Brake Pads; Dunlop American Elite Tires; Ohlins HD 773 Shocks
    Comfort: Police Solo Saddle with Coil-Over Suspension; Extended Reach Footboards; SoftBrake 1 Extended Brake Lever & Reduced Reach Clutch Lever; Extended Shift Levers; Fairing Air Deflectors; Freedom 14" Windshield; Klock Werks Ergo Up Bars; Get-A-Grip Hand Grips; Kuryakyn Magnum Plus Mirrors
    Infotainment: Ultra Tank Console with Headset Connection & CVO Insert; Hidden Radio Antenna; GPS Map Update
    Luggage: Four Point Docking Hardware; Solo Tour-Pak Mounting Rack; King Tour-Pak and Lining; Tour-Pak Wall Organizer; Premium King Travel-Pak; Chopped Backrest Pad; Premium Saddlebag Travel-Paks; Innovative Storage Solutions Tool Bags; Saddle Bag Guard Bags & Bottle Holders
    Appearance: CVO Black Gauges; Carbon Fiber Gauge Panel; De-badged Gas Tank; Skull Emblems over Fairing Mirror Holes; Diamond Engineering 12 Point Engine Screws; Allen Hole Plugs; Piston Muffler End Caps
  3. #3
    Join Date
    Jul 2015
    City
    BLOOMINGTON
    State
    Minnesota
    Posts
    6
    Quote Originally Posted by hulkss View Post
    So this is not exactly as I asked : "Are there other options that anyone knows of that would keep the stock Black Chrome look
    But....I might be interested. How is the sound with this change? I'm looking for a little VOLUME! Thanks!
  4. #4
    Founding Member TomA's Avatar
    Join Date
    Apr 2014
    City
    Battle Mountain
    State
    Nevada
    Posts
    1,689
    If you start searching there are no less then 10 different companies that build black exhaust just depends on what your trying to get out of it. If it's just slipon's so you keep your warrantee then do a search on here as there are several threads.
    2014 Mysterious Red Sunglo
    Stage 1 D&D Boss Fat Cat 2-1 exhaust FP3 tuner
    JW Speaker E2, Custom Dynamic running and tails, 8 plasma rods
    Soundz Customz level 5 Carbon Iron series, 5x7 lids
    Color matched inner fairing and King tour pack with lowers
    Fork fangs, Fairing deflectors, REDA bag bolts
  5. #5
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    468
    Quote Originally Posted by purvistechie View Post
    I think they sound great, louder than stock but not too loud. Great performance, my 120 cu in motor made 120 HP and over 120 TK. And you keep your full warranty. The are pre-drilled for the wide-band 02 sensors if you choose to use the H-D auto tuning module.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
