Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
    Going from 2019 Iron 883 to 2019 Iron 1250
    I haven't been on here too often as of late, but that's because I've been working feverishly out in the lab on my latest build. I bought a new 2019 Iron 883 in April, put 257 miles on it and then disassembled it to make it better, stronger and faster. I installed a 1250 kit for now with .560 lift cams from Hammer Perf. CNC ported heads (with bigger valves), from Hammer, an Energy One performance clutch and a complete front suspension rebuild in order to gain some adjustability. As far as exhaust goes, I have chosen the new V&H stainless upsweep 2-1. Here are some progress pics.
    Attached Images Attached Images
    2015 Vivid Black SGS w/107 motor: V&H Pro Pipe, Thundermax tuner, SE Ventilator Elite AC with K&N filter, Andrews 30T pulley mod, AIM variable pressure clutch, Evolution Industries billet clutch basket, Twin Power compensator eliminator sprocket, HD highway pegs, HD passenger floorboards, RB Racing modified stock swingarm (2" over adjustable), HD 7" Wind Splitter windshield, HD black windshield trim, JM Corp 250W 2 channel amp and Focal 165 KRC speakers in fairing
  2. #2
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
    More pics.
  3. #3
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
    A couple more.
  4. #4
    Founding Member TomA's Avatar
    Join Date
    Apr 2014
    City
    Battle Mountain
    State
    Nevada
    Posts
    1,755
    Looks like fun. Is that going to be your around town beater ??
    2014 Mysterious Red Sunglo
    Stage 1 D&D Boss Fat Cat 2-1 exhaust FP3 tuner
    JW Speaker E2, Custom Dynamic running and tails, 8 plasma rods
    Soundz Customz level 5 Carbon Iron series, 5x7 lids
    Color matched inner fairing and King tour pack with lowers
    Fork fangs, Fairing deflectors, REDA bag bolts
  5. #5
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
    Quote Originally Posted by TomA View Post
    Yes sir it sure is! I'm hoping it'll be a whole lot of fun. The bike was very slow and uncomfortable to ride in stock form, so I decided to rebuild the front suspension, add some trick parts and make it adjustable.
  6. #6
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
  7. #7
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    610
    In 2003 I built a 2002 Sportster 883 into a 1250. It had a Mikuni carb on it and made 97 hp. I used Buell heads, Nallin racing cylinders and pistons. As a stock 883 it made 45 hp.
    2019 FLHCS
  8. #8
    Join Date
    Feb 2015
    City
    Kansas City
    State
    Kansas
    Posts
    72
    That's what I'm talking about hulk! I am hoping to tap 100 hp with it. I need to do a little more research on injectors to see if I should increase the size. I'm just not sure if the stockers will be close to the end of their duty cycle when doubling the power level. I still have the 4.2 gps injectors (with 3100 miles on them), from my 2015 SGS and wonder if they will fit and whether I should install them to make sure I get plenty of fuel? Any thoughts? Lastly, how did you like your 1250 and did you get lots of trouble free miles out of it?
  9. #9
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    610
    If you search around, there are some injector sizing calculators online, sorry I did not bookmark them.
    Mine was a 5 speed and I put a Baker six speed in it. It was fun and very quick. It would pull the front wheel off the road in second gear with ease. I only put a few thousand miles on it. No problems with it.
    2019 FLHCS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
