Results 1 to 10 of 10
  1. #1
    Member yegg's Avatar
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    99
    Main Seal Differenes
    So I pulled the main seal (left side of crank case) this evening using the Jims 775 tool. That thing sure is slick. I was nervous as hell having never done that before but it could not have been simpler. More on that in another post.
    I went to put my replacement seal in but have decided to wait. Below is what I pulled out.
    Take a look at the inner surface. It is hard to see but it is smooth as I expected. Now check out the replacement I have. The inner diameter looks like a bearing packed with grease.
    Is this correct? Has anyone else run across this? I figured I'd post the question before installing it.
    Thanks and ride safe.
    Ride Safe,
    Elliott
    2015 FLHXS - Amber Whiskey
  2. #2
    Administrator hulkss's Avatar
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    505
    Looks like two sealing lips with grease in between.
    2019 FLHCS
  3. #3
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    99
    So that is ok?
    Ride Safe,
    Elliott
  4. #4
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    505
    The main concern is the condition of the shaft the seal runs on. Do not reuse it if there is a groove worn in it where the seal runs. It also needs to be very smooth so the seal will not wear out.
    The seal looks fine as long as it is the correct part.
    2019 FLHCS
  5. #5
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    99
    Got it. I will check the surface of the shaft tonight. The part number is correct but I was confused as it just looks different. I donít really know anything about different types of seals so I figured Iíd ask.
    Thanks!
    Ride Safe,
    Elliott
  6. #6
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    505
    I don't remember for sure, but it may be possible to reverse the seal shaft collar so the seal runs on a new fresh surface.
    2019 FLHCS
  7. #7
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    99
    When you say seal shaft collar, is that the spacer the seal sits around? Iím using the term spacer as that is what my service manual calls it. I just want to make sure we are talking about the same thing.
    Ride Safe,
    Elliott
  8. #8
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    505
    Yes, item 14, spacer.
    2019 FLHCS
  9. #9
    Join Date
    Sep 2015
    City
    Front Royal
    State
    Virginia
    Posts
    99
    Perfect. Thank you. On my diagram from https://partsfinder.onlinemicrofiche...R%20-%20COOLER it shows it as number 19 (24009-06 SPACER, SPROCKET SHAFT). I am riding to Richmond, VA tomorrow on the Duck as that is the closest place that has that spacer. The one on the bike seems fine to me but I am going with "better safe than sorry" and just replacing it. Thank you again.
    Ride Safe,
    Elliott
  10. #10
    Join Date
    Sep 2013
    City
    Luck
    State
    Wisconsin
    Posts
    505
    Yup, my pic is of the Twin-Cooled motor cases.......same part though.
    2019 FLHCS
Posting Permissions
  • You may not post replies
  • You may not edit your posts
