2018 SG CVO Handling issues
Mr Ed
Couple issues
at speeds of 80 to 100 the rear of the bike wants to swap ends the tail start to move left and right.
Anyone else having this issue ?
Also I hate the clutch want my cable operated clutch it hit every time in the same spot.
Any thoughts
Mr Ed
My 18sgs did it above 75mph. Added a true track to the rear and sent my legend suspension back in for a heavy duty spring on my revo shocks (im 250lbs). Those 2 things improved the stability by 80% or so. Hope that helps you
I think I will have to install the True Track I had one on my 2010 SG and it worked well. I didn't think I would need it on a 2018 CVO
Thanks for your help
Are you still on stock suspension? I Highly recommend atleast some aftermarket rear shocks. Legend, ohlins, fox, etc..... anything! Factory shocks really are terrible imo.
Fraser24SG
