Auxiliary Lights
peteperrone
14
Hello,
I have an older set of Kuryakyn Silver Bullet halogen driving lights that I want to install using the Kuryakyn driving light wiring relay kit #2203. It says to tap into a "keyed" 12 volt acc wire. This wire needs to be close to the battery. Anyone have suggestions?
Here are pictures of wires around the battery!
If you remove the left hand side cover you have two connector ports with a black boot on them one is for data link where you can hook a scanner or runner and the other port is an aux port where you can get switched and unswitched power from. They go to different fuses so you will need or look up the wiring diagram to determine which connector pin you will need to draw power from.
