Latest build... Fuel Moto rocks.... ;)
quaddawg
5
2007 Ultra Classic to Street Glide "conversion" lol.
Engine:
Fuel Moto 110" Street Outlaw kit:
S&S Cycle Super Sport heads, with Fuel Moto's CNC porting and all the goodies they put in their Street Outlaw heads
Fuel Moto Severe Duty Cylinders
CP Carillo Pistons at 10.8:1 Static combined with the heads, stock stroke.
S&S Adjustable Push Rods
Wood Performance Knight Prowler TW-999 cams
Wood Performance Knight Prowler directional lifters
Feuling Billet race series high flow cam support plate
Feuling Billet race series high flow oil pump
Feuling hydraulic cam chain tensioners
Horsepower Inc. 58mm Throttle body
Horsepower Inc. 5.3 g/s injectors
Brass Balls F1 Air Cleaner (S&S Cycle Stealth) with K&N Extra tall filter
Harley auto compression releases with Harley ACR add-on harness
DynoJet Powervision
Dynojet Target Tune with wide band O2 conversion
D&D Exhaust black ceramic BoarZilla 2 into 1 exhaust
EMD Sherman valve covers (powdercoated by myself)
All covers removed and powdercoated, tappet blocks, Trans covers, Primary, Derby, Push rod tubes, etc..
Santoro Fabworx complete "Chacho" Kit with wet black powdercoated Chachos and all stainless hardware
Jagg oil cooler with braided line and stand off kit
Suspension/Drive
Ohlins HD357 Reservoir rear shocks (13.5" extended)
Ohlins TK101 separated function front cartridges in custom powder coated fork legs
FloMotosports Rotors with Lyndall racing pads
Pirelli Night Dragon tires
Alto Carbonite clutch pack/plates (Xtra plate kit)
AIM/Fuel Moto variable pressure lock-up clutch
Progressive suspension tour stabilizer kit
Controls etc:
Kraus Raptor Pullback Plate riser adapter
Kraus 8" Isolated Risers
Fly Moto Moto style bars (Powdercoated)
Ignition Switch delete
FloMotorsports adjustable Moto clutch and brake hand levers
FloMotorsports V5 MotoBoards (Floorboards)
FloMotorsports shifter peg on Ness shift lever
Custom black shift linkage with Santoro ends
FloMotorsports Passenger Pegs
FloMotorsports Brake Pedal, with modified stock brake lever
Billet throttle tube and grips
Audio
Aquatic AV Bluetooth Head Unit
Aquatic AV 300 Watt front Amplifier
Aquatic AV Crossovers
Aquatic AV 6.5" Ultra Series front speakers
MB Quart 400 watt rear speakers in speaker saddlebag tops
Kicker 6x9 Rear speakers
6" Passive bass radiators in saddle bags
Noico 80 mil butyl rubber sound deadener installed on fair and complete in both bags
Full integration with factory handlebar controls
Cosmetics/etc
Whiplash Speed Co, custom made Gambler seat
5" extended saddlebags (speaker tops added)
Paul Yaffe Bagger nation Thicky front fender
5" tinted windshield
Windshield bags
Quadlock phone mount with wireless charging
ALL chrome stripped
Miniature led front turns
Modified Street Glide rear turn bar with LEDs
Lay Down style blacked out LED Tail light
Custom LED headlight
FatStyles Headlight trim
light bar delete
CB pod delete
Tour Pak mount delete
Awesome build! ...I just picked up an '08 w/out security fob. Going to install Kraus 8" risers, Fly Moto Bar and T-Rex plate. Did yours have security and how did you delete/bypass the ignition switch? ...thanks
