No Brake lights
jgaanderson
I have a 2008 Street Glide, recently I found out that my brake lights and cruise control were not working. I replaced the rear brake switch and now the cruise works but still no brake lights with either the front lever or the rear pedal. I have checked the fuse, I have flushed the brake system, the pads are good but still no brake lights. Any suggestions on what to check next? Thanks!!
Put your bike in diagnostic mode and read the codes. DTC’s ( diagnostic trouble codes ) may help you in resolving the issue. The images are from my electrical diagnostic manual. The procedure to put bike in diagnostic mode is relatively simple. Hold the trip odometer reset button as you power up the bike.
2015 FLHXS Amber Whiskey; Thunder Max Tuner with Stage 1; Screaming Eagle air cleaner; 4.5 inch RC Exhaust mufflers; Ceramic coated headers; LED turn / run lights front & rear.
