Riser bushings
SGSRKSryder
I currently have 16" LA chopper bars on my '18 SGS. I have changed the bushings now, twice with the latest set being the poly drag specialty bushings. I also have two holes in the clamp with set screws in to help with the movement. My bars still wobble significantly and I am not sure what to do. What do you run and what do you think is the best riser bushing to fix this problem? TIA
Are you positive that it's the bushings flexing and not the bars themselves? As a last resort you could go with solid bushings.
