2011 Street Glide 103 with Hot Restart Issue
Big Willie
13
Hi Guys!
I would like to know if anyone else is having the same Starter issue that I am. Using the search I found a little info, but not enough to get my dealer to fix it before the warranty (extended) runs out.
I have a 2011 Street Gide with the factory 103ci upgrade (“Stage 1+”). Whenever I go for a ride long enough to require refueling, I have an issue with the Starter.
If I fuel my scooter up, go and pay for the fuel and return to the bike to leave the gas station the starter has an issue. After fueling, I throw my leg over the scoot, turn my switch to run, press the start switch and that’s when **** gets weird.
When the starter button is pressed there is a brief grinding sound followed by a cluck and then, if I keep my starter switch pressed, it slowly cranks and starts.
If I let off the starter switch and push it again, it starts normally.
The higher the ambient temperature is, the worse this issue is.
If the bike is shut off hot and restarted right away, it starts normally.
Of the three 2011 – 2012 103ci H-D scooters (mine and friends bikes), two have the exact same issue.
My bike has 8,860 miles on it (I know, I know… 2011 with only 8,860 miles, WTF. I was in an auto accident that kept me from riding for a few years). The 2012 Street Glide that belongs to my friend (with the same starter issue) has around 40,000+ miles on it.
Are any of you having the same issues with what I would call “Heatsink” (hot day, hot bike, bike let sit for 2 – 10 minutes and restarted) where the starter is not working properly when hot?
My “Extended Warranty” will run out next June. I’m in Minnesota. “Hot” days are getting hard to find between now and the end of my warranty. I’ve run this by the dealer. He said it worked just fine when running on the Dyno. I’ve called back to let him know the scoot is still having issues. His suggestion, bring it back in…:mad:
Sorry to drag on! I just wanted to see if we are the only two with this issue. If we are not, what have you done (or had done) to address the issue?
Thank you,
Willie
First off welcome to the fun here. I would take it back to the dealer until they get it fixed or at least find the issue. Funny how your buddies dose the same thing. Maybe someone else here knows more about it and if so they will chime in.
Thanks to TomA for your reply!
At this time, the dealer has said I should bring it in and they will replace the starter under my extended warranty. I have to pay $50.50 per my extended warranty. I hope that will fix the issue. Its better than waiting and watching my extended warranty run out and still having the issue.
Willie
Willie, I remember there being a starter issue before Harley added the automatic compression release. I don't remember if the came stock on 2011 or the 2012 model years. $50 is cheap compared to $450 cost of replacing it out of warranty.
Good luck with your issue.
UPDATE:
Dealer installed a new Starter under my extended warranty. I won't know for sure until the warmer months of next years riding season. I'll roll $50.50 for a NEW Starter even if it is not the fix... I bet it is the root cause of the problem.
Thanks!
Willie
I know this Is an old post but does anyone know what the outcome of this was?
Sent from my SAMSUNG-SM-G890A using Tapatalk
almost ALWAYS the starter clutch/bendix I use All Balls replacements, never had a problem afterwards, straight forward 30 minute replacement, pull the starter, disassemble, install new bendix, reinstall starter. Some years is a PITA due to exhaust clearances, super easy if you have a 2 into 1 performance exhaust.
chops92
