2014-2016 Touring- DIY Chrome/Black Fork Slider Replacement
Spazz
1,856
2014/2016's all have 49mm forks....This job is not as hard as it may seem. Just did this on my 2015 RGS120ST.... The batwing bike teardown is a bit more involved but not that bad.... just gotta get the inner faring rocked forward or removed ( best practice is to remove it since the fork tubes are coming off)
The only SPECIAL tools you need that most will not have laying around:
Motion Pro 08-0121 Fork Oil level Tool- $20
Motion Pro 08-0494 Seal Driver
( You can make your own from modified 2" PVC )
12mm allen socket (about 3" long allen )
19mm allen socket
( Both of these allen sockets are about $35, but you can make your own by cutting up regular allens and a 3/4" is the same as 19mm )
Pick up some new fork seals ( 46514-01A ) and 2 brass crush washers ( 46615-06 ) for 12mm allen in the bottom of the slider
HD calls for 24oz of fork oil IN EACH TUBE to get the proper measurement at the end... this is (3) 16oz bottles ( upgrade to HEAVY WEIGHT oil )
There is not much to taking apart the front end at all.
Remove the Fender, Calipers, and Front Wheel
Remove the ignition switch cover and ignition
Remove your outer fairing, and remove all bolts to free up the inner faring. It's your choice, but I would unplug all the harnesses and remove the inner as a complete unit. ( you can read the manual to get the specifics, my RGS was much simpler )
At this point you want break loose the 12mm allen bolts in the bottom of the fork tubes... DONT REMOVE THEM, you just want to get them off the torque setting so you can remove later.
Now... one side at a time... loosen the top pinch bolt at the triple.
loosen one lower pinch bolt, then holding the fork assy, loosen the other lower pinch bolt and slide the fork assy down far enuf to get the 19mm ( or 3/4" ) allen socket on the top fork tube nut. Re-Clamp the tube using a lower pinch bolt to hold it steady and from rotating.
BREAK THE Tube end cap LOOSE... DO NOT REMOVE it. I found a 12" extension works great to get down in there without hassle and no need to remove your bars.
Holding the fork assy again.... loosen the lower pinch bolt and slide the fork assy from the triple...
( repeat for the other side )
At this point, put a soft pad on the floor to stand your fork assy up as you apply pressure to the fork end cap to remove it.. it's UNDER PRESSURE... so keep a good hold of it with control and downward pressure as you unscrew it.
Remove the spring spacer, washer and spring and drain the tube... pump it a few times to get most of the fork oil out.
Move to the bench and pad it with a clean towel to lay it horizontal.
re-insert the spring and spacer and apply hand pressure.. this will allow you to remove the 12mm allen on the bottom of the slider.
Once the bolt is out, remove the space and spring and tilt the fork assy to slide the damper tube and damper spring out.
Remove the spring clip that retains the seal in the top of the slider... VERY EASY to remove with the small flatblade screwdriver.
Using the fork tube as a slide hammer against the seal, remove the seal and separate the fork tube from the slider.
Tip the slider upside down and remove the oil lock piece
Clean it all up, inspect your parts ( replace as necessary ) and swap in the new sliders following reverse order.
Use a piece of masking tape around the top of the fork tube ( folding over about 1/2" inside the tube ) to install new seal on the fork tube. This will prevent nicking the new seal.
There are some steps for re-assembly that I won't go into as this point since I am providing a link below to a manual.
THERE IS NO EXACT FLUID MEASUREMENT GIVEN for the 2014-2016's... you can get close my measuring what you drain, but best to use the Fork Oil Level Tool following the procedure in the manual.
2014-2016 Touring bikes all have 49MM forks, so here is a link to an online manual ( 2014 Touring ) to obtain specific step-by-step instructions and torque specs....
https://docs.google.com/document/d/1gXrzoWX0YcAk_i6mjO4-xieMDihhMSQrmI-boTYbzMI/edit
Took me about 3 hours total... GOOD LUCK!
If you are a VISUAL type person that needs to SEE things to better understand... There are youtube videos that will give you a good understanding on the teardown and rebuild of the fork assy.
The ones I originally posted ( not mine of course) have been privatized and no longer available... sorry
Looks good
Off topic but didn't you have chrome bars on your SGS ?
Yeah... YMB's... ordered 14" chrome YMB'S for the RGS... still waiting. These are 12" KST Outlaws... loners
Sent from Note4
Looks really nice! I like the black replacement on there. Looks sharp! You have too much time on your hands obviously! LOL
David
Well... considering I have been recovering from knee surgery since 5 Oct... I have a little time
Sent from Note4
Turned out great Spazz. Very impressed with the willy shiny legs. The upper sliders look good too!! Lol
Yes Chad... THANK YOU for the hookup! I have gotten a lot of complements on the contrast of the cowbells and lowers....
As far as quality from Willy Shiny.... FANTASTIC!!!! I got them within 3 days ( only a state away, SOCAL) and perfect finish.
Nice work Spazz! But my eyes keep looking at the 120ST and the bottle of Slick Mist lol
Sent from my SM-G928T using Tapatalk
Spazz like alway very helpful and it does look fantastic. I'm in the process of taking my forks apart I didn't have the hex head sockets for the fork cap or the bottom hex. I traveled all over town looking for the hex head sockets and struck out. So now I know what size hex head sockets I need to order on the inter web. Thanks Again. By the way I'm going in the other direction I'm getting the lowers powder coated black.
Hey spazz did you have a problem with a leak ever on drain bolt? Put chrome lowers on, and it leaked so I impacted the bolt on a little more and I believe I have stopped the leak, giving it a couple days of watching to make sure.
Is their something I did wrong? Worried with impacting about breaking the bolt and can't really hand tighten it
never a problem on my end....
Biggest thing is to make sure the bolt and NEW crush washer are clean. never reuse the crush washer, they will leak. I can't say why you can't tighten by hand, it has a tq spec.... the onlyreason why this could be is if you reused your crush washer.... other than that, maybe the threads somehow got boogered up
Shop told me to re use the crush washer, so I'll have to pick some up, only the one and it's not even dripping but if I put a shop towel on it I can see just a little spec
Crush washers are a one -time use.... sometimes you can get away with 2 times if you are lucky...don't think you got lucky.
PHXflyer
