2014 Rear Fender options
Crowbova
Anyone use a 2009-20013 cvo fender on a 2014 or know if it will work? Love the look of the older cvo fender more than the new style.
The old style won't work unless you doe some grinding and rewire the plug under the seat. I have it (topshop fender) on mine and it took quite a bit of effort to get it to work. It does look better then the new set up tho.
That fender looks sweet. I thought top shops were very easy set up just bolt.on? They seem a bit pricey too.
The fender bolts up fine, the old style lights interfere with the new saddle bag support brackets. Some grinding had to be done on mine to provide the needed clearance.
Jimrogers74
