2014 SG real axle torque spec?
msquad
49
Doing my 1000 mile maintenance and checking the belt tension. Need to tighten up the rear axle. Anyone know the torque spec for the rear axle. I think it is like 95 to 105 foot-pounds.
Thank you.
Well, when one use to ask questions on the vrod forum, there would be answers in like 10 minutes.
Put about 80 miles on since doing this and I'm still alive so far...went with 100 ft. lbs. at this time.
BTW, the belt tension was many marks off (of course) too loose.
Hulkss afternoon, its a two part torque, tighten to 15-20 ft. lbs. then adjust belt, tighten to second torque of 95-105 ft. lbs. nothing like splitting hairs though.
You are correct on the torque setting.
Whinny
