2014 Steering Head Bearing Inspection & Adjustment
Nice work hulkss. How often should you check the bearing.
Check them once to know your OK, then Harley recommends every 25,000 miles. That is also the recommended lubrication interval.
I would suggest the following simple test once a year:
1. Support the vehicle with the front tire off the ground
2. Swing the handlebars from stop-to-stop to check for smooth movement.
3. Grasp both fork legs near the axle and shake front to rear while checking for looseness or a clunking sound in the head set.
Don't pull your bike off the lift :eek:
