2014 Street Glide Hydraulic Issues
kharris037
Lost and hope someone has had the same issue. 2014 Street Glide Special Edition. I was just riding and all of sudden i try to pull in clutch to stop and nothing. I was fortunate enough to shift down to first gear and come to abrupt stop. Hydraulic fluid was leaking from the bottom of trans/salve cover. I replaced the Hydraulic salve with (rekluse one), master cylinder, screaming eagle clutch plates, and new hydraulic line. Bleed the complete system and still yet the clutch won't engage. I bleed the system from the slave to the master and don't see any air bubbles. The transmission i can shift in to gears no problem while on stand and find neutral with no problem. Im just lost on what else it could be. I appreciate any help or suggestions. Thanks
Dr.fixed-throttle
