2014 Street Glide Special - Gear Indicator Not Working
Redroadking
I have a 2014 FLHXS and the gear indicator is not working and therefore the cruise control is not functioning either.
I rode the bike last week and everything was fine. I washed the bike this morning and now I'm having this issue. I turned the bike off and when I went to start it again it would not start while in gear. I put the bike in neutral and it started. Thought that was strange but didn't realize there was an issue. Then I was riding on the freeway and went to engage the cruise control. It turned on but it would not set the speed. Then I noticed the gear indicator was not working. So I assumed they are related somehow. I came home and disconnected the battery thinking it may have gotten water in the switch box and needed to reset. After I disconnected the battery and reconnected it the bike would start in gear with the clutch engaged but the gear indicator and cruise still do not work. I have disconnected the battery again to see it it needs and extended time period to do a complete reset.
Has anyone experienced this with their bike? Any ideas as to what may be going on here? Any advice would be appreciated.
TIA
RED
I would check the 2 wire switch on top of the transmission,could just be bad connection from washing it.(right side of trans.)
TIA
RED
Were you able to solve this issue? I had the same thing happen this weekend. I washed my bike in the morning then went on a ride about noon time. I noticed that the gear indicator would not go on after 4th gear. Then after riding for about 10 min i noticed that none of the gears would show up on the indicator. I took the bike on the freeway and the bike's indicator or cruise control would not work. I let the bike sit for about an hour and I rode it again and the gear indicator started working again. So my thoughts it that water probably did mess with the switch...weird I never had issues before.
Jimrogers74
