2014 Turbo StreetGlide
Bobz74
2014 Street glide Special
53 Series Aerocharger Intercooled
ThunderMax
107" Full Build
Water Injection
Manual Dual Stage boost controller
Electric shifter w/ EFI Auto clutch
Dirty Bird bags, fenders & Batwing
Custom one off side covers
MC Bagger bolt on
26" DNA wheel
Soundz stereo system
Bike has made 206hp on the dyno at 18psi, however it lives most days at 12psi
cool side cover . I was thinking of making one for my ride to hide my aero. what cam, injectors ,and tb are you running. Have you swapped to a chain. I am going to build a 124 when i get back from daytona. right now I am running a stock 103 with cams and the aero at 11lbs.
I didn't mind the turbo out in the open, however its really cool hidden most people don't even realize its turbo.
Running a custom cam from Drago Bike works (Highly recommend calling Frank)
69lb injectors
58mm TB
No Chain drive yet, belt can handle alot of power its the hole shots it doesn't like
If your running 53 series turbo it might be a little small for 124. Talk to Brad at Aerocharger and Frank at Drago Bike works, they have done some testing with different size motors and turbos.
Yep I spoke with Brad. He said I should be good up to 200-250 hp mark before I need to step up to the 66 series. I have spoke with Frank also. I had a guy who was going to buy my 53 setup but totaled his 2016 and will probably pickup a 2017 so my aero wont work. I already have the 124 kit and Kendal Johnson is going to go through the bottom and do the timkin and case bore and install my s&s crank. I am shooting for the 200s hp with less boost until i save up to buy the 66.
Great! Sounds like your talking to all the right people and have a solid plan. Did you consider trying water injection. In our group we have 5 turbo bikes and 2 of us run water and got rid of all detention.
