2015 Turbo Street Glide New LED and BOV
Leds look cool, what's the story on the turbo? What brand, size and power are you putting out.
Aerocharger Turbo kit. 53 series variable vane, 9lbs boost ,S&S 575 cams . hadn't put it on the dyno but the owner at Aerocharger has a Road Glide with the same build with 7lbs boost and is pushing 150hp and 170lbs tq. so I am guessing I am probably around 160hp 175-180 lbs tq at the wheel. again no dyno numbers yet just doing the math based on average boost numbers 7hp per 1lb boost at 9lbs = 63hp + 5-10 hp for the intercooler.. with cams the stock engine should be around 100 hp so we say 90 on the low side. 90hp + 63hp + 8hp(intercooler)= 160 hp roughly. It sure is a blast to ride though lol
Impressive stats, I bet that is a blast to ride.
Roughouse_R_75
