2017 radio static
Shortbed12
5
Hello all ,new member. I have a 2017 street glide got it a few months ago
Now my FM radio has A LOT of static
HELP
thanks ken
Check the antenna conections...i don't use the radio but mine were all shook loose
Have you changed your headlight or other lights on the scoot?
Welcome to the fun. As Mojo stated have you changed the headlight or the stereo components or LED marker. stop/blinker lights ????
I got a lot of static on mine too.
I ended up routing the antenna under my seat.
When I went to disconnect the antenna I noticed the thumbscrew that tightens it to the mount was completely loose.
I tightened it up good when I did the re-route and my reception definitely improved, though I still rarely use it cause I got used to listening to my Ipod all the time...
  • Like
Reactions: Stacy
Hi this is Ken ( shortbed12)
The antenna was loose on my bike also , tightened it up now it's fine .THANK YOU VERY MUCH
duckworth
