2018 Boom Audio Favorites Button
surfsup1955
190
Since day one my Favorites Button has never worked properly. I am able to set it up as per the instruction manual, then after a week or so it no longer functions as advertised. The only cure is to perform a PreCal reset and reprogram everything all over again since the reset deletes all user (my) preferences. Then after a week or so, the Favorites function no longer works, rinse and repeat...
[The good part is: I’ve done this so many times I can reprogram all my user preferences and reconnect my phone in about 2 minutes.]
This is a known issue from year’s past yet there are very few articles out there via Google to be found. I suspect most riders don’t even use the Favorites functions because they’re not really all that important. However, I want every part of my $2k Boom system to work as advertised.
So yesterday while riding around the county, I noticed that my HD dealer wasn’t very busy so I decided to go get this problem logged in and documented.
The tech (who owns a gorgeous 2016 Roadglide Special) was pretty much clueless about the Boom Favorites functionality, but I went through it with him and he was up to speed in no time. He said he never used it on his Boom. I had already figured that out
Moving along. So he pulled out the manual and did the cursory troubleshooting: pull the 50A fuse; rebooted all computer systems; then reflash latest Boom firmware; but nothing cured the problem.
So the next step was a series of phonecons with the HD mothership wherein we finally/actually got to talk to an engineer. He told my tech that HD is aware of this issue and is working on a firmware upgrade to hopefully fix this and a few other issues. Maybe being released by end of July?
Just FYI.
Just wanted to update this issue.
As of the latest Boom firmware update, this seems to now be fixed.
That is all. Carry on..
Well that's a good thing they are fixing these issues. Some just take longer then others
Roughouse_R_75
