Amp/speaker help
gorillasoldier
Pittsburg
I recently got a couldn't pass it up deal on a RF pbr300x4, a pair of RF tms69 6x9's for the bags and some RF fairing speakers. Power supply plug and wires included, other speaker input and output wire plugs snipped off with about 2" tails.
Apparently this amp is a little older model and i didn't realize that.
Does anyone know if i can or where i can purchase a harness to make this all plug and play? Or will.i have to basically fab it all up myself?
This page will get you new speaker connectors with longer wires. It will show 3 different sets the ones that you'll need, if you want longer wires, they are 1560-56544-01 and 1560-56568-01.
As far as the connectors at the speaker pods, you can order them from H-D's website, p/n's 72272-07, for the socket pins, ×4 and 69200271, for the connectors themselves, ×2.
But you'll also need to have your radio flashed to flatten out the EQ curves so you don't blow your amp or speakers. This is a MUST DO when adding an aftermarket amp and speakers.
  • Like
Reactions: gorillasoldier
Definitely checking those out! I knew about the need to flash, just want to get this all set up before i do that.
Thank you!
duckworth
