Ape Hangers
I wanna know how far up on the ape hangers I can go without having to redo my cables.....
Dealership said 10" I've heard some say 12" but had to reroute some of the cables to make them work.
2015 Street Glide V&H vo2 naked V&H OS 450 destroyers V&H power duals with V&H fp3
On Rushmore bikes 10" for sure, I have 10" LA Choppers on mine, and as rtodd79 said 12" with rerouting.
I know for a fact you can do 14's with reroute of lines as there is a thread on here somewhere. Did 16's on mine and had to replace all the hydraulic lines and that was way more then the bars themselves. You will need the one extension even going 10's for a little extra room.
12's are easy with just wiring extensions... 14's can be done with a reroute of the cables... but it's tight... not unsafe tight, but tight...every inch of slack is taken up
I had to reroute with my 12's. I think these are wider bars tho. Maybe there is more slack that I didn't find?
Zip ties on top of the triples and dislodge the cables from the holder on right side of neck on the frame
Im new member just installed 12 inch bars no problems no add ons friend installed 16 inch had harley tech install them as side job on weekend rerouted lines and worked without extensions guess it osys to know what your doing
Sent from my SM-G935P using Tapatalk
Roughouse_R_75
