Arlen Ness Hot legs/ Ring of Fire Bullet lights
vannesb
Hope this is the right area just wanted to supply information put the Arlen Ness Hot legs on my 2014 Street glide and love them. Things to be aware of
1) Fender on HD bolt from the outside in and have a nut on the inside of fender. You will have to drill out nut so you can run hardware from the inside of fender into legs. The stock hardware will not work and will need shorter bolts in some cases. Most put custom fenders on when replacing lower legs I stuck with using stock fender for now until I increase front wheel size.
2) You will need sills even though they say that they come with kit. Cost me another $80.00
Other that that was not a big issue
Arlen Ness Edge cut Ring of Fire Bullet Lights.
1) It states on the new 2014 wont need a load equalizer which is some what true. The blinkers will blink like normal but the dash will be VERY fast like when you have a light out.
Love the products just a few small issues.
El Guero Jay
