Cam Bus And Dash Switches
simmons5
10
All of the blank switches in the Dash next to the ignition have Plugs in them when you take the Cover off. I know this is the "Cam Bus" system. Can anyone explain where the other end of the plug is or goes and what the Cam Bus System really is. Thanks In Advance for the knowledge.
This is a page out of the 2015 Electrical Diagnostic Manual it gives an explanation of the “CAN BUSS SYSTEM”
As far as the switches go they go back to the “BCM” ( Body Control Module)
2015 FLHXS Amber Whiskey; Thunder Max Tuner with Stage 1; Screaming Eagle air cleaner; 4.5 inch RC Exhaust mufflers; Ceramic coated headers; LED turn / run lights front & rear.
noithatquetram
