Clutch play adjustment
pyuchem
102
So recently I changed my clutch to easy reach clutch by soft brake. I like the reach on this clutch, problem is I've to pull it in all the way and still get a feeling that it is not completely disengaging. Before the switch I was able to start my bike in gear with clutch pulled in, Now it does not do that.
So I was wondering if there is any adjustment somewhere that I can play with to increase the friction zone as well adjust it in such a way that I don't have to pull the clutch all in to work.
Thank you for ur inputs
There is a switch behind the level inside the housing that neutralizes to start. Make sure the switch isn't broken or is being contacted by the new lever.
If you're looking to adjust the clutch itself so that you can change the engage or disengage point, there is no adjustment with the hydraulic clutch.
noithatquetram
