CVO exhaust?!
360rider
hey guys,
Do we need to do anything with the computer/fuel managment if we go to the CVO exhaust? Does it make a difference with performance and sound? I am just curious if that would be a good way to go....
Not an expert..... but it's my understanding that any mods (within reason) downstream of the mouth/intake (i.e. exhaust) are handled by the stock computer. It can make allowances for "some" variance in fuel mixtures.
Simple exhaust changes typically don't require a change in air/fuel mixture changes without other modifications.
Simply (and crudely) put:
Having a larger diameter pisser (urethra) doesn't allow you to drink beer any faster (or more of it), it still has to go through the whole digestive system. It only sounds different when it hits the porcelain of the toilet. :p
Flashes and aftermarket tuners will enrich the mixture "more" than the stock computer to allow for cooler exhaust temperatures and allow for more modifications that will exceed the stock computer's ability to compensate..... i.e. cams, intakes, head/valve work, larger pistons, stroke, injectors, etc... major stuff (the "system" mentioned above).
I don't know about the performance or sound.... other than the fact that my buddy has a '13 CVO. Sounded nice to me, but he eventually changed it and got a tuner..
I just put on some CVO slip ons. They look better than the stock and sound a little bit better. I am going to get some Full Sac baffles for a little more noise.
Hi Guys!
There are several SGF members running stock CVO mufflers. They flow very well and are compatable with modified engines up to around 100hp.
Just adding the mufflers does not necessitate an ECM modification.
The CVO muffs will loosen up sound wise after a few thousand miles. I have 6K on my stock 2014 CVO muffs and they really sound nice without Swapping to Fullsac baffles.
And yes, I think they look really nice
Low & Slow,
Blues
