Engine light cimes on. How do you get codes off the bike
mwacosta
Engine light came on yesterday. I have a 2012 street glide. How do I get the codes off the bike?
Thanks in advance. New to this site.
Mike
Mike
Hey Mike.......did you check your shop Manual to see what they say about that??
It's different on the 2014 bikes so I can't lend a hand.....check the manual It's in there!
One method to access DTC's
"Harley Diagnostic Codes
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the “t” looks more like a “╘” )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer. "
Thanks for this post. It was a great help. I changed my bars on my 2017 SGS used some cable lube to get the wires through. Must not have gotten it all off before connecting the wires. It kept the check engine light on. After following your post I reset all codes and the engine light went off and all is well.
Thanks again
Greg70
