Front wheel
Nitrous05
Hey guys. New to the bagger scene and I was wondering. What's the biggest wheel you can run on the front of a 09 sg without any fender mods. I'd like to eventually do a 21 if I don't have to redo the front fender but I would be happy with a 19 like a 2014 factory wheel. Thoughts?
You should be able to do a 21" under that fender. It might be close and if it is just drill out the back holes on the fender mount and lift the rear of the fender to give you enough clearance.
21" works fine.. Anything larger you need different trees and or rake
noithatquetram
