Well, I've seen these things on the web for a few years, and I've always wanted one.
So...... today, I pulled the old mock-up Buick 215 cubic inch all aluminum V8 block out of the stalled '73 Vega Kammback project to see how hard/easy it would be.
WOW! It took 5 minutes to build the rough draft.....
1. After separating the rod caps, I simply slid one rod bolt into a head bolt hole. The other rod bolt just hangs in the lifter valley pan area.
2. The pistons are almost level.... will need some tweaking/leveling to sit flat.
3. Cut some old blue jean grease rags up to keep the glass from getting scratched/nasty from the old carboned up pistons.
4. Added Sunscreen, Bug Spray and a bottle of hootch to the cylinders for effect...... sitting on top of the 2x4 in the crank area to raise them up and out of the bores
After a good de-greasing and some clear coat on the steel rods/pistons/cylinder walls, I think I just might have a new back porch/deck coffee table.
