Harness
Semba
2014 SGS. Bought the accessory switches and supplied harness. The harness plugs into existing(already on the bike under the left hand cover) harness. The existing harness does not have power, nor is there power to existing harness where the switches plug in at the fairing. Battery and fuses are good, and yes i had the ingnition in both run and accessory with no luck. What am I missing here?????
Which plug did you plug it into... Black or Grey? Black is acc... Grey is ECM. Not sure if they would even fit in the wrong plug.. I would hope not, but I do know you have to push them together REALLY HARD to get them to seat properly...you should hear a click when they seat.
BTW... the 3 wire harness has a ground, ACC ( switched HOT ) and constant HOT.
