iPhone 5s mount
I know you asked for iPhone 5s but I use RAM mount for my iPhone 6, GPS & water bottle holder, they have wide variety of mount setups for motorcycles. I use a bigger X-grip for 7" GPS.
Harley makes a nice mount. It secures to the existing brake or clutch mount. I have a 6plus so it will hold most phones
Have you looked at the mount the Iron Aces has? They are a sponsor here and her link is on the left side of this page. Take a look.
I use a RAM mount also. I mounted a RAM ball using a hex head bolt and acorn nut to finish it off thru the bottom of the right handlebar mirror mount. I then ran the RAM arm under the handlebars, giving it a low profile and used an x-grip to hold the phone...works great, its inconspicuous and convenient.
Check into the MotoXtek.... very small footprint.. i love mine and fits my Note4 with Otterbox case
http://www.motoxtek.com/
Thanks for the shoutout @SGS Mark, we certainly appreciate it! Although I'm not certain what model year @MikeyG is looking to use his iPhone 5 on, the following link will take you to our Street Glide Mount which is compatible on all '13 & older batwing fairing models. I've also attached a photo of an iPhone 5 attached to it so you can see how it would look on the bike when properly mounted.
If @MikeyG has a '14 or newer batwing fairing models, we are currently wrapping up our initial production run on our Rushmore Street Glide Mount and hope to have it available for purchase sometime in mid-October.
Hope this helps!!
Lindsey :0)
http://www.ironacesspeedshop.com/street-glide-iphone-smartphone-android-zumo-power-vision-gps-mount-13-older-harley-davidson-batwing-models/
Take a look at Kuryakyn's phone mount. It's very solid and a great piece of gear.
I'm all about low profile......Think I'm going with moto grip for now, but I'll definitely be looking at Iron Aces some time in october (mine's a 2014.....)
Thanks Everyone!
Thanks Everyone!
You will be very pleased! The best part is the ball/socket butterfly connection is easily undone and thrown in the saddlebag when you park. Great feature.
I'm considering the MotoGripper mount, but nowhere in their website do they show how easy it is to install and remove the e-device from the two side grippers. They say it has 18lbs of gripping force, but how do you install the phone? I assume that the two side claws are independently "sprung" and you slide the side of the cell phone into one claw and push against the rigid mount while using one hand to support the entire mount, and then pulling the other claw out with your other hand?
My 2+2 bars (w/ polyurethane riser bushings) shake a good bit during idle, so I assume that the Moto Gripper holds the device securely?
You just spread the sides and drop it in... done... always under spring tension.
Sent from Note4
