Klock Werks 2014 Hinge Inserts
hulkss
622
Added these to the saddlebag hinges: Special Inserts
It's a bit of a challenge to get the reflectors out. Apply some heat with a blow dryer. I was able to pry the reflectors out carefully and did not resort to tapping a screw into them. I put 3M double stick adhesive only on the ends of the insert as the bags are curved a bit and the inserts are flat.
I just hit mine with plasti dip a couple days ago figured it would still be a while before something like these came out.i would have waited and did the same as you had known .
Sent from my Street Glide using tapatalk
Both of you did a great job! I like the SPECIAL badge... but the blackout looks great too!
almmy
