Left rear running light not working..PLEASE HELP HELP
Nebraska2868
4
Put on tri bar from Custom Dynamics and Led turn signals in rear. Everything works except the left rear running light. HELP HELP
Yes I did that and also swapped blub's and still don't work
So the LED bulb doesnt work in EITHER side? Take it back... if the LEFT SIDE housing is not working, thats another issue..
ensure you have the contacts oriented right... it will fit the wrong way..
EDIT: Never messed with the tribar... is there wiring involved or plug and play... could you have messed up something there?
Try removing the tribar and see if you can just run the LED's... isolate the issue....
It has to be something with the wiring I guess. Its not the bulb's. Its just the left side one not working. Turn and brake work on that side just not the running light.
There can be NO dielectric grease in the socket or on the contacts. Go back and clean everything with alcohol. The Custom Dynamics directions make this very clear.
If the socket worked/works with the 1157 bulb then it's not the socket.
Greg70
