New OEM Parts off my '16 FLHXS
zhlevy
9
New OEM Saddlebag Support Bracket Inserts (Black), HD part # 90200547 -- $30
New OEM Saddlebag Latch Levers (Chrome), HD part # 90200902 & 90200903 -- $50
New OEM Passenger Streamliner Foot Pegs (Chrome), HD part # 50211-04 -- $100
New OEM Center Console (Chrome), HD part # 69214-08 -- $100
Just bought this bike and previous owner had it blacked out by Rommel HD Annapolis. He included this box of parts that were all removed before he even took delivery of the bike new. All in plastic/bubblewrap, handled with care by Rommel HD and have been in a box ever since. Let me know if you're interested.20180816_162715.jpg20180816_162505.jpg20180816_162427.jpg20180816_162311.jpg
Sent from zhlevy '16 FLHXS
Also have a NEW LeNale Engineering Cooling Fan, Black, 2014 - 2016, Harley FLH Touring
· Gloss Black– forged & welded steel housing
· Motor circuitry sealed to withstand all weather conditions
· Components silicone mounted to resist temperature and vibration shock
· Inner housing sprayed with rust proof coating
· Wires bonded to prevent metal fatigue and shafting
· Integrated marine grade manual on/off switch
· Wiring harness PVC vinyl sleeved
· Weatherproof Harness Connector (Touring)
Motor Specifications:
· Ball bearings permanently sealed
· Blades and frame plastic UL 94V-0 high temperature rated
· Speed 12,000 RPM
· Maximum airflow - 205 CFM @ 13.8 VDC
· Operational voltage range VDC 7.0 – 13.8 VDC
· Rated voltage system – 12 volts VDC
· Load amperage - 3.07 amps
· Input power - 36.70 watts
· Maximum air pressure – 2.102 Inch H20
· Noise – 67.5 dB-A
· Comes Pre-wired to plug directly into the Harley wiring harness
· Includes kit to relocate the factory horn
Just bolt on and plug in!
Bump
Also have the following OEM parts available:
Stock windshield $40
Stock shift and brake control levers $40
Stock brake arm $40
Stock Heel/Toe shifters $40
Dm me if you're interested, open to offers
jdtech17
