Quick Detach Lock
eberky
So I installed the "lock" for the quick detach tour pak. Now one question....how do I unlock it??? The key won't fit!
You should have gotten two barrel type keys. One long (the one in your pictures) and one short one. I am able to unlock mine in any possible configuration.
If neither one will fit you have the lock oriented the wrong way. The lock should be facing the same direction that the original latch was.
Thanks Maxx - sure enough the other key is a shorter one and works. I never thought to check the second.
lol... Neither did I the first time. Had a serious "Duh" look on my face when I figured it out.
noithatquetram
